Two Codes ?
Old Mar 27, 2007 | 02:35 PM
cdiddy's Avatar
cdiddy
Question Two Codes ?
Got these two codes after towing a load. They are P0603 and PFFFF.
Anybody know what these mean? My check engine light came on a few times and then would go off. Not sure what that would mean.
Old Mar 27, 2007 | 03:19 PM
nlemerise's Avatar
nlemerise
Is the 0603 DTC continuous or does the code go away when you turn the engine off?
Possible causes:
Battery or PCM has been disconnected.
Battery cables loose or poor connection.
Battery discharged.
Open in KAPWR (Keep Alive Power) circuit.
Blown fuse (#2)
PCM.
Check for other codes.
Key on, engine off.
Clear DTCs.
Cycle key off, then on.
Perform retrieve Continuous DTCs.
PFFFF: I have no idea at all...sorry.
Old Mar 27, 2007 | 03:40 PM
bdrummonds's Avatar
bdrummonds
What are you using to read the codes?
Old Mar 27, 2007 | 03:54 PM
cdiddy's Avatar
cdiddy
I am using my hypertech III to read the codes. I had it on level 3 when towing and after I cleared the codes only the P0603 comes back but no engine light.
Old Mar 27, 2007 | 04:14 PM
ron's power stroke's Avatar
ron's power stroke
P0603 Internal Control Module KAM Error
i got this after un hooking power..i cleared it 3 or 4 times with my AE before it would stop coming back..
Old Mar 27, 2007 | 04:32 PM
cdiddy's Avatar
cdiddy
Why is this just now comming on for the first time. Anybody know about the PFFFF?
Old Mar 27, 2007 | 06:53 PM
Uzumati's Avatar
Uzumati
PFFFF is not a valid code
Old Mar 27, 2007 | 11:27 PM
cdiddy's Avatar
cdiddy
So do I need to be worried about the P0603?
Old Mar 28, 2007 | 07:12 AM
Uzumati's Avatar
Uzumati
Not with a programmer or chip. If you remove the chip/programmer and clear the code and it still comes back then there are a few things to check.
fifty-two_f1
Jul 18, 2010 10:15 PM
donaldm
1997 - 2003 F150
Jul 15, 2007 10:28 AM
The Phenom
1997 - 2003 F150
Jun 16, 2004 08:20 PM
Trexx
Bronco II
Dec 8, 2003 03:12 PM
The Diesel Dude
Jan 13, 2003 01:35 PM
