Engine cuts out when raining ?
Old Mar 27, 2007 | 10:07 PM
budman-mo's Avatar
budman-mo
I have a question for a friend.
It's a 2002 F250 with a powerstroke.
She says when it rains it has spells of cutting out.
A local mechanic has been looking at it without luck.
I am thinking something in the fuel system is obviously getting wet and shorting out. Any suggestions of where to look.
Old Mar 27, 2007 | 10:25 PM
Uzumati's Avatar
Uzumati
Check the windshield seal. Water can dip down the firewall and get into the PCM connector.
and
Check the CPS pigtail water can get in it and cause cutouts.
Old Mar 27, 2007 | 10:47 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Does it happen when it is first started or while underway? If underway, you may want to check the CPS or camshaft position sensor. It is on the front of the block by the crank dampener and when it gets wet it is prone to fail. Fairly common when the oring goes bad and water gets in there.
Old Mar 27, 2007 | 11:08 PM
squaredancer's Avatar
squaredancer
Ohhh, that is so a familiar problem. Long story short, thanks to the experts on this forum I changed out the CPS and haven't had a problem since.
Old Mar 28, 2007 | 12:27 AM
VQ2Fast4U's Avatar
VQ2Fast4U
Ill 2nd the CPS, also my ICP plug was giving me trouble when it rained. I cleaned the connection and pluged it back in, havent had a problem since.
Old Mar 28, 2007 | 08:28 AM
budman-mo's Avatar
budman-mo
As always I figured the experianced here would have a good answer for the problem.
I will pass it along.
Thanks.
