gas tank replacement?
Old Apr 15, 2007 | 09:17 PM
Torque1st's Avatar
Torque1st
Posting Legend
I have been using an electric transfer pump for 20+ years (same pump, an old Carter). It has about 10' of 3/8" hose on both the inlet and outlet. The pump is mounted on a flat piece of wood. I also have a long electric line permanently connected that plugs into a power outlet or cigarette lighter. I just coil everything around the pump and throw it up on a shelf. The interesting thing is that when I first start up the pump the seals around the power connections and case leak gas for a moment until the seals swell up. The power connections are tight and I disconnect the unit from the vehicle power connector so no chance of sparks. Only a couple drops leak out tho.
There are a number of gas tank cleaning and repair threads in the Garage forum. There may be a number in the fuel systems forum also. Check them out!
Old Apr 15, 2007 | 10:27 PM
rusty7983's Avatar
rusty7983
yeah the cigarette lighter is a great idea. most of the time i was always close too and used the battery. but your idea is better and great.
Old Apr 19, 2007 | 12:24 PM
jfarcas's Avatar
jfarcas
Replacing the tank, if you've got the cash, in my opinion is the way to go. I just installed a plastic replacement tank from BroncoGraveyard, and it was a chore, but totally worth the time and effort.
octaneforce
Nov 13, 2011 10:34 AM
pdqtimetrialer
Oct 27, 2011 05:30 PM
C. Lee Colbert
15
Aug 23, 2005 08:30 PM
KJMacLean
Sep 12, 2003 08:05 PM
