no boost when cold
Old Mar 26, 2007 | 09:39 PM
fgibby's Avatar
fgibby
no boost when cold
my 02 has no boost when cold. it wants to stall and barely runs. if i let it warm up for 15 min. it will run fine. no codes or check engine light.
Old Mar 26, 2007 | 10:32 PM
Pocket's Avatar
Pocket
More than likely your exhaust backpressure sensor cannot get an accurate reading. This is typically caused by too much soot clogging the line. There is a metal pipe running from the passenger's side exhaust manifold to the front of the engine where the exhaust backpressure sensor sits (just behind the idler pulley). Remove the sensor and clean the soot out of the pipe with a long wire brush. Gently clean off the sensor and put it back together.
Without the sensor getting a proper backpressure reading, the exhaust backpressure valve stays closed when you try to accelerate. It is supposed to open up some when backpressure is too high. However, the purpose of the backpressure valve is to warm the engine faster in cold weather. So try cleaning out the line and see if that helps.
Old Mar 26, 2007 | 11:05 PM
fgibby's Avatar
fgibby
thnx-i'll gibe that a try
josh8440
6.7L Power Stroke Diesel
13
Feb 2, 2017 05:23 PM
g tinsley
Jul 11, 2015 03:14 PM
1973dieselhighboy
Competition
Feb 6, 2015 12:17 PM
lesterd
Apr 30, 2014 01:31 PM
rmcdonald72
Feb 5, 2014 08:05 AM
