Cam Sensor
Old Mar 27, 2007 | 06:08 PM
MPlayer's Avatar
MPlayer
B_THOMPSON,
I had my '95 do the same thing with any trailer hooked up. I checked all my connections and still had a problem with it stalling out. I pulled out my spare CPS and swapped them out and the problem went away. I would have never thought the trailer would cause that to happen. Those CPS are strange. Like they said swap it out and see if it cures it. Good luck
Old Mar 27, 2007 | 06:19 PM
andywe's Avatar
andywe
CPS pricing
Heya guys. It's been awhile!!!
I need a CPS and I see that Ebay is no better deal than one of the member sponsors here on the site. All week Ebay has been running up around $90.00 + shipping for new CPS (they spike at the last minute) with 8-10 bids by the last day.
Millenuim Ford (who is a sponsor here) has a web price of $100.00. As it happens, I bought my PST from them last June. Good dealer, stands up to their word. When I bought it, the brake caliper seized on my way home from the dealership. They paid a tow (expedited it too), and replaced the entire front brake system: Calipers, rotors, pads on both sides, and also new lines to the brake cylinder at theri expense. Even after I hammered them down to $5200.00 on a 94.5 PST % speed with 156k on it, clean with 1 owner.
http://www.y2kford.com
Old Mar 27, 2007 | 07:56 PM
whiskeyrichard's Avatar
whiskeyrichard
I went to the stearlership yesterday to get a CPS to keep in my tool box for a long trip I am goin g to be taking. I did not have time to wait and order one online.
The first price the girl at the counter gave me was 190.00. I almost crapped and she noticed. I said I may have to go check the international parts shop because the price was too high.
She took pity on my wallet and brought the price down to 150.00
I did not know they could even do that. Next time I'll know to hmm and haahhh over the price and try to get them down some.
WR
Old Mar 27, 2007 | 09:08 PM
andywe's Avatar
andywe
Correct part # for 94.5 7.3L DI CPM??
Ok, I have gotten two different part numbers referenced for the same CPM. 1 is more expensive than the other but they are both supposedly the same thing. I bet Cuda Jim or some other PST brainiac here knows the answer so I buy the right part, so here goes:
Part #1: 4C4Z-12K073-AB - $81.00
Part #2:F6TZ-12K073-A - $101.00
Is there a difference?
Old Mar 27, 2007 | 09:50 PM
FL_BWAB's Avatar
FL_BWAB
o.k....stupid question but i have to ask since I make pretty long trips pulling a pretty heavy load with my truck. How do you change the CPS? Everyone says its easy, but I dont even know where it is? Also if you replace it, lets say now, should you "still keep an extra in your glove box"?
Old Mar 27, 2007 | 11:55 PM
Randy Pederson's Avatar
Randy Pederson
I got my original #'s from cuda's gallery. When I went to International they had a totally different # . I checked back with Jim and he said it was the replacement for the one I was looking for it's a blue 1 not black.The Inter. part# is1807339C92 apparently it replaces 2 or 3 different cps part #'s.
Old Mar 28, 2007 | 12:02 AM
Randy Pederson
FL BWAB, the cps is on the frt of the engine. all you need to change it is a wrench or socket(10mm?) and a small dab of grease to lube the O-ring . unplug the old 1 and pry it out gently with a slotted screwdriver and put it in your glovebox as a spare.Install the
new 1 and plug it back in you're done .
Old Mar 28, 2007 | 05:00 AM
smokey352's Avatar
smokey352
I want to thank you all for your help in my problem, I think they found my problem, the turbo exhaust tube was like 90% blocked, so will see later today when I pick it up from shop.
Old Mar 28, 2007 | 05:50 AM
trpisok's Avatar
trpisok
Fyi
Camshaft Position Sensor (CPS)
(Ford) F6TZ-12K073-A 94-96
(Ford) F7TZ-12K073-A 97+
(International) 1821720C99 (below engine 375548)
(International) 1825899C93 (above engine 375548)
(International) 1807339C92 (DT466 CPS, reported to advance timing, and stronger signal)
95PSDieselP
Aug 13, 2012 05:51 PM
lesster
27
Jan 18, 2012 10:26 AM
jbballcoach
Jun 19, 2007 09:10 PM
myst
Jan 26, 2003 11:53 AM
