Cam sensor
Old Jan 12, 2012 | 10:36 AM
lesster's Avatar
lesster
Red face Cam sensor
Has any one had troulble with the cam sensor? how hard is it to change?
Old Jan 12, 2012 | 10:39 AM
fordpride's Avatar
fordpride
Welcome to FTE !
Very common problem. It takes about ten mins. to change. Get on from ford or international
Old Jan 12, 2012 | 11:01 AM
lesster's Avatar
lesster
Will do, Thanks. its just that I'm in Mexico right now, will have find a parts store
Old Jan 12, 2012 | 11:16 AM
Ford4Life7.3's Avatar
Ford4Life7.3
Welcome to FTE! We have a few members south of the boarder here. The CPS is an easy fix, and a common problem. One wire connector and a bolt (10 mm i think?) is all there is.
Old Jan 12, 2012 | 11:50 AM
lesster's Avatar
lesster
Thanks for the info. am in Puerto Penasco, was going to go home today, but the truck is not running very well, I took it to sds mechanic, he is looking for a sensor
we will better prepared next time
Old Jan 12, 2012 | 11:56 AM
MHammer21's Avatar
MHammer21
welcome and good luck, I always travel with 2 spares...
Old Jan 12, 2012 | 01:21 PM
Ford4Life7.3
X2 on the spare, i keep one in my tool bag
Old Jan 17, 2012 | 10:25 AM
lesster's Avatar
lesster
we got the truck running and I made it to the USA, the truck wouldnt start in the morning, so is now in the shop getting the wires to the injectors repaired
Old Jan 17, 2012 | 11:17 AM
MHammer21's Avatar
MHammer21
will it turn over, or nothing at all? could be a sensor, Injector work is extremely expensive and it may not be the root cause. Could it be Glow Plugs?
Old Jan 17, 2012 | 11:27 AM
lesster's Avatar
lesster
We have a burnt plug in that goes throught he valve cover on the left front of the motor, and there a hole burnt through the wire inside the valve cover. it has been hard to get parts in this small town, with the weekend and all
Old Jan 17, 2012 | 11:29 AM
lesster's Avatar
lesster
it will turn over and even fire, but it sounds like the pistons are going come the side of the motor
Old Jan 17, 2012 | 11:31 AM
lesster's Avatar
lesster
I changed the cps, myself also.
Old Jan 17, 2012 | 11:43 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question
Where did you buy it?
Old Jan 17, 2012 | 12:01 PM
lesster's Avatar
lesster
Just got the Truck Back $702.00 and we're on the road again.
Thanks for your Help again
Old Jan 17, 2012 | 12:04 PM
MHammer21's Avatar
MHammer21
what did they do for you? [the shop]
