cam sensor ?
Old Aug 4, 2012 | 05:20 PM
95PSDieselP's Avatar
95PSDieselP
cam sensor ?
I am about to do my cam sensor, is there any tips or know how, that i can use for this job? like tricks or anything will help please and thank you.
Easier to gp through fender or under truck or what??
again thank you
Old Aug 4, 2012 | 05:30 PM
BLADE35's Avatar
BLADE35
how do you know its BAD???????
Just curious
Old Aug 4, 2012 | 06:38 PM
Crash16's Avatar
Crash16
I did mine from under the truck.
Old Aug 4, 2012 | 08:35 PM
cheezit's Avatar
cheezit
we dont have cam sensor problems very often. I think I have done 2 maybe 3 sence 2003.
but to replace it is stright foward its sits behind the p/s pump and easy to access from the bottom.
Old Aug 4, 2012 | 08:41 PM
bismic's Avatar
bismic
IIRC - an 8mm flexhead gearwrench is a helpful tool.
Old Aug 5, 2012 | 12:23 AM
95PSDieselP
Thank you i will do it as soon as it gets here lol
And i know it is bad because i hooked it up to a comp and that was one of the codes and when i reved it up the rps fluctuated like a misfire cause by the cam sensor being bad, also this is the first sensor been changed in this truck sense 03 so yeah i think it is time anyways
Old Aug 5, 2012 | 12:31 AM
BLADE35's Avatar
BLADE35
oh sounds like it been a good truck 1st sensor since new thats AWESOME
Did it ever stall????
So does the RPM Gauge Jump Around alot??
Post if it helps Im Curious as always
Good Luck with it
Old Aug 5, 2012 | 12:45 AM
95PSDieselP
Good Luck with it
Nah never stalls just sluggish with a misfire when i try to get going. and also no the Factory dash gauge does not fluctuate but you can see on the computer the RPM's jump around when it should stay up, also when you rev up and let of the throttle the truck should go straight back to idle fairly quick but mine takes forever
Old Aug 5, 2012 | 01:01 AM
BLADE35's Avatar
BLADE35
ya your probably right bad Cam sensor
if you get Board and have a dvm you can try this
If you want to verify those circuits, you can connect a DVOM to both the CKP and CMP circuits of the middle PCM connector. Set your DVOM to Hz. On the CKP circuit, you should be seeing 150 to 200 Hz when the engine is cranked over (directly proportional to 150 to 200 RPMs). On the CMP circuit you should get a reading of 1.1 to 1.9 Hz when the engine is cranked over.
PCM PLUGS PINOUT
https://www.ford-trucks.com/forums/a...7&d=1338749081
Old Aug 5, 2012 | 09:53 AM
cheezit's Avatar
cheezit
if your having issue with real rpm bouncing, running funny I suspect somthing different. but thats just me.
Old Aug 5, 2012 | 10:05 AM
tjustice's Avatar
tjustice
That's about how my trouble started except for the code....Same symptoms anyway, still have no clue as to the issue, working on wiring harness now....
Old Aug 5, 2012 | 10:49 AM
m-chan68's Avatar
m-chan68
Are you changing the entire main engine wiring harness? If so, that usually sounds like the fix.
Old Aug 5, 2012 | 11:37 AM
95PSDieselP
What would you say it was?
Old Aug 5, 2012 | 11:38 AM
cheezit's Avatar
cheezit
icp sensor and connector or sticking ipr, hell what do I really know just another guess
Old Aug 5, 2012 | 01:01 PM
Sheryle's Avatar
Sheryle
Sorry not meaning to hijack the thread but my 04 6.0 will not run. Saw this thread while searching. What numbers should the CMP be when cranking. I have a SG2 and it reads 9999 for CMP. Been running terrible and today it will not start.
Thanks, I will start a new thread once I have more information.
