Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
Hey Morris
Old Mar 25, 2007 | 09:34 AM
51dueller's Avatar
51dueller
Hey Morris
Here's the axle ratios for a couple of the trucks in your yard.
Blue 1978 F-150 - H4 = 3.25:1 limited slip
Green 1979 F-150 - 14 = 3.00:1
Red 1970 F-100 - 17 = 3.25:1
Blue 1969 F-100 - 17 = 3.25:1
I got a 9" carrier with 3.70:1 but needs a pinion seal, bearings and spider gears. It's from a 1969 F-100 300 I-6/3psd. I'll trade it for 12 pack of Coca-cola. It would probably only cost $100 to fix it if you steal the spider gears from another carrier.
Old Mar 25, 2007 | 09:48 AM
96sherm's Avatar
96sherm
mmmmmm...coca cola...and here i thought i was the only one boycotting pepsi... ...of course, i know what you're thinking...
Old Mar 25, 2007 | 09:51 AM
51dueller's Avatar
51dueller
The only Pepsi product I drink is Dr. Pepper and Crush.
Old Mar 25, 2007 | 09:52 AM
96sherm's Avatar
96sherm
yeah that Dr pepper stuff is pretty good!!
Old Mar 25, 2007 | 11:32 AM
Fomoko1's Avatar
Fomoko1
Nathan, thanks for the info on the axle ratios.
This is good news, I was hoping for 3.25 and the limited slip is a nice bonus.
The 3.70:1 might be a little much for hiway, any idea of the RPM at 100kmh?
Old Mar 25, 2007 | 12:12 PM
Snowking's Avatar
Snowking
There is a calculator in the articles/specifications
Old Mar 25, 2007 | 01:06 PM
51dueller's Avatar
51dueller
100 km/h
235/75/R15 tires 28" diameter
3.70:1 ratio
C-4 = 2800 rpm
AOD = 1850 rpm
3.25:1 ratio
C-4 = 2500 rpm
AOD = 1600 rpm
I've made a Excel spreadsheet a couple years ago with all the conversion and calculators.
Old Mar 25, 2007 | 01:11 PM
96sherm's Avatar
96sherm
i think the 3.70 would be a better choice, with an aod. better in the city, more jump off the line...
Old Mar 25, 2007 | 01:19 PM
51dueller's Avatar
51dueller
My truck has 3.73:1 gears with an AOD but I also have 32" tires. 235/85/R16
Old Mar 25, 2007 | 01:21 PM
96sherm's Avatar
96sherm
that would turn it into a bit over 3.55 or so wouldn't it??
Old Mar 25, 2007 | 01:45 PM
51dueller's Avatar
51dueller
It has a final drive ratio the same as 3.25:1 and 28" tires. I have also have an identical axle with 4.10:1 but the gears are bad.
Old Mar 25, 2007 | 03:40 PM
Fomoko1's Avatar
Fomoko1
This would be real good, I`ll see if I can find it but this info is good for now, thanks.
The 3.25 sound good till I get the AOD rebuilt, then the 3.50 or 3.73 would be ok.
Old Mar 25, 2007 | 09:58 PM
Dustin1690's Avatar
Dustin1690
Blue 78 which one is that i know he haas a blue 77 i know he has a green 78 maybe im missing some out there during my scouting~
Old Mar 25, 2007 | 10:49 PM
Fomoko1's Avatar
Fomoko1
Dustin, I think Nathan means the 77.
I`ll check the 77 F150 axle code on it tomorrow to be sure.
The 3.25 is what I`m after for the 56 for now. Lots of 9'' Ford rear ends here to replace the 77 one if I do use it.
Old Mar 26, 2007 | 10:28 AM
preppypyro's Avatar
preppypyro
Id go for the limited slip too
