IDM location
Old Mar 25, 2007 | 07:06 PM
Zwalters's Avatar
Zwalters
Exclamation
Originally Posted by strokin_it7.3
It's not a diode, its a resistor. More resistance=more pressure, right?
Edit- Oops, i read up and saw where i started using the term "diode" which would certainly fry the IDM. Sorry for the mistake.
Edit again- Zwalters i was looking at your signature. Rudolph Diesel invented the Diesel engine. Adolf was that guy with the square moustache...
I was waiting to see how long it took for someone to realize that. Sharp eyes. Keep looking for the next one.
Now as for the resistor it depends on how it is oriented in the circuit. I can tell you I know more about most circuits than the average joe. It's part of my job to troubleshoot them and fix them. I'll do the research and give alittle better explination of this voltage increase. Voltage shouldn't change circuit reaction time. Pulse modulation is controllled by oscillators which if the current not voltage is increased then the oscillator would create faster pulse modulation. I will post and see what this guys is up to.
Old Mar 25, 2007 | 08:57 PM
Zwalters's Avatar
Zwalters
Can someone send me the joe servo link please?
Old Mar 25, 2007 | 09:02 PM
Uzumati's Avatar
Uzumati
http://www.forgotton.net/diesel/idmmod/index.htm
There ya go
Old Mar 25, 2007 | 09:05 PM
John311t's Avatar
John311t
Where did you get those spark plugs from? I have been trying to find a set but everyone looks at me funny when i ask for them for a 7.3 diesel. One guy even laughed at me so i just gave up my search. Please help!!!!!!
BTW here is the link, idk if it is gonna work though.
Old Mar 30, 2007 | 05:24 PM
Mach1's Avatar
Mach1
I have been a board tech for 10 years and used storage scopes and logic analysers. I now work on semi-conductor equipment for 15 yrs..Working on equipment down to the atomic level and troubleshooting as well..
By intensifying the voltage to the injectors, the injectors mechanically slam shut and slam open in a shorter period of time..thusly changing the timing..advancing it..The injectors also dump quicker, because of the changing of the timing of the events.
I do preform the IDM mod on the IDM 100, 100, 120 series IDM's. have probed more then one IDM module, as a matter of fact we are finding alot of limitations to the stocker, to hold back the true power of the 7.3...Got to have the electronics if you want to make the power..
RubberDuck
87
Oct 9, 2013 07:58 PM
BroncoEx
6.4L Power Stroke Diesel
Aug 25, 2013 08:02 PM
ltatkinson
Aug 1, 2008 01:00 PM
silverz98
31
Jun 20, 2007 02:49 PM
