IDM location
Old Mar 24, 2007 | 11:57 AM
Hiflyer746's Avatar
Hiflyer746
IDM location
Where is this thing and whats it look like? is it mounted on the fenderliner or on the firewall? Is it hidden? Its not inside the fender or anything is it?
Tim
Old Mar 24, 2007 | 12:16 PM
SolidGround's Avatar
SolidGround
Yes, Inside the fender.
Old Mar 24, 2007 | 12:38 PM
pullinair's Avatar
pullinair
Drivers side wheel well liner, gotta drop it. PITA!. Once you get it dropped look up inside the fender, right behind the F series badge and you will see it.
Old Mar 24, 2007 | 02:36 PM
Hiflyer746's Avatar
Hiflyer746
wow
Man that was a PITA. I mean was it really necessary to mount it back there? C'mon.
Tim
Old Mar 24, 2007 | 02:42 PM
pullinair's Avatar
pullinair
Tell me about it! Doing the IDM mod?
Old Mar 24, 2007 | 03:57 PM
SolidGround
Tim
You don't want that thing exposed to anything, but yes, I can think of several 'easily available' places to put it. Should've booted it next to the PCM on the firewall.
I think they (Ford) thought that would be an ideal location away from the elements. Like the PCM, inside the truck! I've seen guys running without the fender liner, not so smart, IMO.
Old Mar 24, 2007 | 05:09 PM
Hiflyer746's Avatar
Hiflyer746
IDM mod,
I'm just replacing this one. . . but I've just recently read about the mod. . . what is it and what does it do?
Tim
Old Mar 24, 2007 | 05:31 PM
pullinair's Avatar
pullinair
I havent done it but it increaes electrical input to each injector thus giving each injector a faster reaction time. Something about replacing a diode in the IDM that requires soldering. When I was researching the IDM i kept seeing this mod over at the D-stop and goes by the name of "the joe servo" mod?? I think. I havent seen any one doing it over here. Do some research. Something lie ten horses can be brought out and mostly good feedback from those doing it.
Old Mar 24, 2007 | 11:10 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Tim, Check this out. I have th RTV and i have the diodes. If you want ONE i can ship one out. I have a pack of 5 and i would like to keep three here. I got the diodes from DigiKey.
http://www.forgotton.net/diesel/idmmod/index.htm#9
Old Mar 25, 2007 | 02:19 AM
Mach1's Avatar
Mach1
Might consider, NOT putting diodes in the IDM mod.
My IDM is on the drivers fender, where it should be(of course I relocated it)
You dont have to remove the inner fender, just loosen the back side of it, pull it out a ways and reach a long extension up in there, 10mm..
Old Mar 25, 2007 | 02:25 AM
John311t's Avatar
John311t
Well, i was bored tonight and did some reading. According to Servo, the one who invented this mod, said that on the 01 and newer IDMs the procedure that is listed on that site will fry the IDM. I have the link to the other forum if anyone is interested PM me.
Old Mar 25, 2007 | 04:46 PM
ernesteugene's Avatar
ernesteugene
I've read the Joeservo write up on Diesel Stop also, and he says that jacking the voltage up from 110V to 140V decreases the turn on time from 560uS to 440uS. I see how this gives more hp with an OEM PCM, but why can't a chip provide the same benefit without the IDM mod? Seems like a chip can advance timing and increase PW to get a similar effect.
Old Mar 25, 2007 | 04:57 PM
John311t's Avatar
John311t
I dont really know, i have it done on my idm, but it was done before i got the truck so i do not know much about it, i was just posting that before people blow up IDMs.
Old Mar 25, 2007 | 06:32 PM
Zwalters's Avatar
Zwalters
Exclamation
I'm not familiar with the circuit itself, but it doesn't sound right. You can't jack up voltage by a diode. A diode is just a check valve in an electical system, depending on the diode type. I will do some reading and find out what this guys is claiming. Something doesn't sound right.
Old Mar 25, 2007 | 06:47 PM
PowerstrokeJunkie
It's not a diode, its a resistor. More resistance=more pressure, right?
Edit- Oops, i read up and saw where i started using the term "diode" which would certainly fry the IDM. Sorry for the mistake.
Edit again- Zwalters i was looking at your signature. Rudolph Diesel invented the Diesel engine. Adolf was that guy with the square moustache...
