Automatic Transmission Disengaging/Slipping?
Old Mar 29, 2007 | 06:32 PM
Hookem Idaho's Avatar
Hookem Idaho
I was waiting to get through a 4 way stop this evening and stepped on the throttle and didn't move. The engine revved up, but it acted like I was in neutral. I shifted from drive to 2nd and low, but nothing. I shifted into 4 hi and low, but still nothing.
I put it in park and shut it off. When I restarted it, the tranny engaged just fine. I drove a few miles, then it acted like it was slipping. I shut it off and restarted, and again it ran fine until I got home.
I there a sensor or something that could be going out that lets the transmission know that it's supposed to be engaged?
Thank you in advance for any advice and suggestions.
Old Mar 29, 2007 | 06:42 PM
jvoigt's Avatar
jvoigt
Did you notice if your Overdrive light was flashing?
Old Mar 29, 2007 | 06:50 PM
Hookem Idaho
I don't think it was, but I was little on edge at that point and wasn't looking for it either.
Old Mar 29, 2007 | 07:56 PM
Kwikkordead's Avatar
Kwikkordead
Is your ATF level up? Sounds like it's running out of fluid.
Old Mar 29, 2007 | 09:32 PM
Hookem Idaho
Fluid level is fine.
Could it be a plugged filter? If so, why would it be fine after I restarted the engine?
Old Mar 29, 2007 | 09:52 PM
Kwikkordead
It's possible. Only way is to drop the pan and see what's up.
If it is full of crud......., well it came from something and that something is most likely the friction material in the clutch packs.
Rebuild time.
Old Mar 30, 2007 | 08:04 AM
Hookem Idaho
I'll pull it today and check it out.
If it is rebuild time, any suggestions as to whose kit to use and I also read something awhile back about the early '99 torque converters having problems?
Old Mar 30, 2007 | 08:14 AM
Kwikkordead
Sorry, I don't know who has the best rebuild kit if you want to fix it yourself.
BTS makes the best transmission from what I've heard. Pricey but it's the last transmission you'll have to buy.
Old Mar 30, 2007 | 09:41 AM
Hookem Idaho
Just pulled the pan, and there is somethng that looks like a sea urchin growing over the drain plug.
Oil is dark and smells a little burnt.
I'm disappointed as I don't pull much weight (20' camp trailer in the summer and 4 place snowmachine trailer in the winter), had the fluid changed about 20K miles ago, and there is only 145K miles on it.
Old Mar 30, 2007 | 05:19 PM
Kingtim7's Avatar
Kingtim7
Thats your magnet.
Old Mar 30, 2007 | 05:53 PM
John311t's Avatar
John311t
145K is not bad for the original trans, my truck is on is third trans and i have 155K on it.
Alsride
29
Jul 25, 2016 09:27 PM
SultanGris
6.7L Power Stroke Diesel
26
May 23, 2015 01:34 AM
jonnio
1997 - 2003 F150
Jan 6, 2015 09:40 PM
ckellf350
2004 - 2008 F150
Nov 13, 2014 07:31 PM
mattri
13
Jun 20, 2014 09:34 PM
