Cleaned Maf sensor now will not run
Old Mar 22, 2007 | 07:35 PM
abarth80's Avatar
abarth80
Okay I cleaned my Maf Sensor and the truck starts and dies. What gives never touched the wire. Help 1999 5.4L Phone Ford and they want $270 for a new one. Any help would be great. When I uplug it runs fine can I unplug and drive to the shop?
Thanks
Mark
Old Mar 22, 2007 | 07:59 PM
torkum's Avatar
torkum
What cleaner did you use?
Old Mar 22, 2007 | 08:13 PM
abarth80's Avatar
abarth80
Electrical contact cleaner Leaves no residue
Old Mar 22, 2007 | 08:36 PM
abarth80's Avatar
abarth80
Got it just have to make sure none of the hoses fall off. Now have to go and change my shorts.
Old Mar 22, 2007 | 08:38 PM
torkum's Avatar
torkum
Have you tried disconnecting the battery for 10-15 minutes to reset the pcm? This will set new settings to the clean MAF.
Old Mar 23, 2007 | 01:15 AM
pronstar's Avatar
pronstar
Make sure you mounted it in the correct direction.
I put mine on backward once, and it did exactly what you describe.
There's an arrow that indicates what direction the air is supposed to flow.
BTW you can get a remanufactured MAF from Autozone for like $70 after the core charge (you have to give them your old one).
Old Mar 23, 2007 | 01:13 PM
ReAX's Avatar
ReAX
I talked to a K&N rep yesterday, and he said the epoxy in the MAFs eventually leak down on to the sensor and cause issues. Take a good look at the wires, you maybe having this issue.
Old Mar 23, 2007 | 01:30 PM
RIsuperduty89's Avatar
RIsuperduty89
When cleaning the MAF sensor do you have to disconnect the battery??
Old Mar 23, 2007 | 01:31 PM
ReAX's Avatar
ReAX
No, but you really should pull the MAF out of the vehicle. That will allow you to spray the heck out of the sensor with getting any in the engine and it will be disconnected so no shorts.
Old Mar 23, 2007 | 04:35 PM
RIsuperduty89
Thanks ReAX... i did take the whole unit out of the truck and sprayed the hell out of it.
joe blow
Jun 4, 2013 12:36 AM
xc4jokestomper
26
Jul 28, 2010 08:58 PM
fderflinger
Aug 21, 2007 06:38 AM
superduty lee
Modular V10 (6.8l)
18
Jun 4, 2007 07:08 PM
thelonerangerxlt
Dec 4, 2004 06:04 PM
