IAC help needed asap
Old Jul 22, 2010 | 03:56 PM
xc4jokestomper's Avatar
xc4jokestomper
i was told i should check my idle air controller and clean it along with my MAF sensor. i alreayd cleaned my MAF. it was already clean as a whistle. but im having troulbe trying to find my IAC. can someone tell me where its at? a picture would be even better. its a 95 5.0 MAF if that helps any.
also how would i clean it? would MAF cleaner be okay to use on it?
thanks guys.
Old Jul 22, 2010 | 04:28 PM
nnewman's Avatar
nnewman
It's on the side of the throttle body. Here's a picture.
86f350's Avatar
86f350
Hope this link works for you !
http://lib.store.yahoo.net/lib/musta...er-8693-02.jpg
Anyways remove it and there will be a hole that carbon likes to build up in.
You can take a wire coat hanger and dig the crud out. I'd use brake clean myself or carb cleaner but whatever you use just make sure you install a new gasket or that your old one is still in good shape when you put it back on.
Old Jul 22, 2010 | 04:29 PM
nnewman's Avatar
nnewman
I've used carb cleaner or something like that (maybe MAF cleaner) before & it worked fine.
Old Jul 22, 2010 | 04:30 PM
xc4jokestomper
thank you. i got it pulled off. how would i go about cleaning it? i got the whole valve part off. anything i should do to check it? i read somewhere to make sure its plugged in and and turn the key to the on position wihtout startign it and see if it moves in or out. would spraying it with MAF cleaner be okay?
Old Jul 22, 2010 | 04:32 PM
ymeski56's Avatar
ymeski56
Der Postmeister
After cleaning the IAC, test it at warm idle.http://www.fordfuelinjection.com/?p=39
I hope you only used electronic contact cleaner or MAF cleaner on the MAF!
Old Jul 22, 2010 | 04:36 PM
xc4jokestomper
alright.
the main reason why im doing all this was because i took it to my friends dads garage and let them run the codes on it because my engine light has been coming on and going off. but it said their wasnt any codes on it. i told them that when your going slower the trucks starts to jump a little bit but if you give it more gas then it would come out of it and straighten up. they told me to check the MAF wich i did and it was absolutely spotless, and then the IAC. wich im doing now. do you guys think this would be the cause maybe? or should i be looking at something else?
Old Jul 22, 2010 | 04:38 PM
xc4jokestomper
whats the MAP? i used the MAR sensor cleaner on the inside of the sensor. i didnt spray the plug in or nothing.
Old Jul 22, 2010 | 04:47 PM
86f350's Avatar
86f350
the MAP sensor is located on the firewall. it will be towards the passenger side and have a vacuum line going to the intake plenum and have an electrical plug to it. Manifold Absolute Pressure
Old Jul 22, 2010 | 04:50 PM
xc4jokestomper
oh then no i didnt clean it. ive only cleaned the MAF so far. how would i go about cleanign the IAC? just spray some MAF sesnor cleaner in it? what could i use to clean the carbon out with?
Old Jul 22, 2010 | 04:53 PM
86f350's Avatar
86f350
either a pick or small screw driver or like i mentioned above use a wire hanger. just scrap it all out of there. whats your truck doing ? Is your idle fluctuating ?
Old Jul 22, 2010 | 05:21 PM
ymeski56's Avatar
ymeski56
Der Postmeister
Originally Posted by xc4jokestomper
alright.
What octane? How old is the O2 sensor?
Old Jul 22, 2010 | 05:26 PM
ymeski56's Avatar
ymeski56
Der Postmeister
alright.
The IAC is always a good thing to look into at when no codes are present, as it is one of the things that can fail w/o resulting in a code. Have you checked it's function yet as mentioned on the link?
Old Jul 22, 2010 | 05:28 PM
xc4jokestomper
my idling is fine. just regular gas. the o2 sensor is pribably original. so 77k miles on it.
while im dirving down the road it start jumping when im going slower but if i give it more gas it quits. maybe not enough fuel or air?
Old Jul 22, 2010 | 05:32 PM
xc4jokestomper
im going to go out and check the function right now.
