Modular V10 (6.8l)
Cleaning the MAF Sensor ?
Old May 23, 2007 | 12:20 PM
superduty lee's Avatar
superduty lee
Can you tell me where the MAF sensor is on my 2002, and how should I clean it ?
Old May 23, 2007 | 12:46 PM
juterbock's Avatar
juterbock
Disconnect the air cleaner as though you are going to change it and then look in the pipe towards the engine. It is a super fine wire, do NOT touch it, use electrical contact or MAF cleaner from your auto parts store (both come in an aersol can).
Old May 23, 2007 | 04:07 PM
hydro_37's Avatar
hydro_37
you can wipe it carefully with a q-tip after you spray it
Old May 23, 2007 | 07:21 PM
TeamMudd's Avatar
TeamMudd
i used "brake clean". i was told to use a cleaner that DOES NOT leave a residue. worked for me, and it's like a $1.00 for a 24oz can at wally world!
Old May 23, 2007 | 07:27 PM
Antelope V-10's Avatar
Antelope V-10
I paid $5 or $6 for a can of CRC MAF cleaner at NAPA. Shot it about 7-8 times let it dry and put it back together.
Old May 24, 2007 | 10:59 PM
Miamifan1354's Avatar
Miamifan1354
I used alcohol in a spry bottle and used a cue tip. Worked fine.
Old May 24, 2007 | 11:28 PM
RIsuperduty89's Avatar
RIsuperduty89
I'd buy the MAF cleaner sold at most car parts stores. Just spray it real good and let it dry, i wouldnt even use a Q-tip.
Old Jun 2, 2007 | 08:58 PM
imper's Avatar
imper
ok so do u spray the wire? im confused on this. some people say to spray the wires. havent found a exact detail on how to clean it. just want to make sure i get it right.
Old Jun 3, 2007 | 12:51 AM
TheTedster's Avatar
TheTedster
I cleaned it in all 3 of my vehicles and all I did was spray it with the electrical cleaner which is fast drying and leaves no residue. I didn't bother with the q-tip because I didn't want to risk breaking anything since it's so fragile.
Old Jun 4, 2007 | 06:14 AM
imper's Avatar
imper
so what the heck do u clean?
Old Jun 4, 2007 | 03:17 PM
Big Orn's Avatar
Big Orn
Welcome to FTE, imper
As was stated above, look downstream of your air filter, in the tube. There you'll see the sensor - it's the only thing you see just past the filter. That's the MAF sensor.
Old Jun 4, 2007 | 03:18 PM
imper's Avatar
imper
so you spray the wire inside the tube?
Old Jun 4, 2007 | 03:24 PM
Big Orn's Avatar
Big Orn
LOL!!! Sorry about that. Yes, you spray the wires. But, just to keep it simple - spray what you can see and be done with it.
Sometimes old gray-haired farts, such as myself, don't realize they don't say enough. We do, howsoever, realize it when we say too much. It's a sad thing....
Old Jun 4, 2007 | 03:26 PM
imper's Avatar
imper
its ok. i just searched and never really found anything that was postive. i found one that said to spray the connections, as in the plug. ha. no wonder im only getting 7.6 miles to the gallon.
Old Jun 4, 2007 | 03:34 PM
Big Orn's Avatar
Big Orn
No - don't spray the connection. That's like crumbling an aspirin and sprinkling it in your hair for a headache....
There are very tiny, very sensitive wires that make up that sensor. They detect the air passing from the filter into the throttle body. When you disconnect the filter housing and lift that tube a little so you can peek in there - you'll know what we're talking about.
