DSO codes & vin plate?
Old Mar 22, 2007 | 12:02 PM
BigBlue88's Avatar
BigBlue88
I'm trying to find out stuff about my truck. There's nothing listed on the VIN sticker- no DSO codes, no axle codes, no nothing. Just GVW ratings and date of manufacture (01/76). It's a laminated blue sticker. There's no stickers under the hood, either. No vacuum diagram, no emissions calibration code, no sticker on the air cleaner or valve cover. A VIN decoder told me that it's a 1976 F100, manufactured in San Diego.
It's a Texas truck, with very minimal emissions equiptment- PCV & catalytic converter. There looks like there might be a line running down the framrail for an evap canister, but there's nothing under the hood to support it.
1976 F100 Ranger XLT
2wd, appears to be 3.50 factory ratio from speedo gearing, but swapped by PO to 3.00.
300 six, T18 4-speed.
power steering, manual brakes, add-on style Ford-brand AC (separate panel by glove box, no factory radio.
Can anyone point me in the right direction? Resources? Places to look? I'd like to find out what the factory emissions calibration and axle configuration is.
Thanks!
Old Mar 22, 2007 | 01:32 PM
Mil1ion's Avatar
Mil1ion
It should be on the door where it latches and look kind of like this. top of page.
http://www.clubfte.com/users/mil1ion...ruckCodes.html
Vin# F10B???????
Trans = A
axle
3.50 = Code 16
or
3L50 - H2
Old Mar 22, 2007 | 02:41 PM
BigBlue88's Avatar
BigBlue88
Yeah, VIN looks right.
I've got a laminated blue sticker on the cab door jam, just below the striker. I'll post a photo of it tonight when I get home. I'm also going to try to find a chassis VIN plate; see if it matches (just for fun!).
Old Mar 22, 2007 | 03:56 PM
Mil1ion's Avatar
Mil1ion
So you are now saying there isn't a rating plate on the door either?
Old Mar 22, 2007 | 04:56 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
There is both a Rating (VIN) Plate and a BLUE Certification Label on these year trucks.
OP: Your are listing the info from the Certification Label, not the Rating (VIN) Plate.
(Dennis: See page 18 in general info section 73/79 book)
Old Mar 22, 2007 | 07:50 PM
Mil1ion's Avatar
Mil1ion
I know about the label.
The OP never mentioned Not seeing the rating plate...everything but.
Old Mar 22, 2007 | 08:10 PM
BigBlue88's Avatar
BigBlue88
That's cause the "OP" didn't see the rating plate on the door.
Never thought the VIN plate would be on the door itself. But there it was on the door. DSO code 52, axle code 12.
Thanks for the help, NumberDummy and Mil1ion!
Old Mar 22, 2007 | 08:13 PM
Mil1ion's Avatar
Mil1ion
DSO 52- Dallas
Code 12 - 3.70
Old Mar 22, 2007 | 10:21 PM
BigBlue88's Avatar
BigBlue88
Thanks again. I'll be very interested to see what it reads with a tachometer installed, and see what the actual gears are. I don't think it's 3.70, but I could be wrong.
Old Mar 23, 2007 | 03:59 AM
NumberDummy
San Diego? LOL NO Ford assembly plants in San Diego...ever!
Once there was Long Beach & Pico Rivera, Richmond in NorCal...all long gone.
Old Mar 23, 2007 | 08:09 AM
BigBlue88's Avatar
BigBlue88
Pretty sure the VIN decoder said it was somewhere in SoCal, but I could be wrong.
Old Mar 23, 2007 | 10:45 AM
NumberDummy
There were assembly plants in SoCal. Trucks were built for years in Long Beach. The factory moved to Pico Rivera in about 1956-57, because the ground under the original Long Beach factory on Henry Ford Avenue was slipping. I don't think trucks were built in Pico Rivera. Truck production moved to Richmond CA, then San Jose which is south of San Francisco. Line from old song.."Do you know the way to San Jose?"
If your truck is CA built, San Jose is the place. VIN code 5th digit is R.
VIN decoders are not from Ford, and are only as good as the research put into the effort.
Old Mar 23, 2007 | 02:25 PM
BigBlue88's Avatar
BigBlue88
Probably San Jose then. Only CA plant listed on this 73-80 VIN decoder:
decodevin2.php
Anyway, thanks!
JDenver
22
Jul 23, 2014 09:22 PM
Dieseldoe96
31
May 9, 2012 11:14 PM
pmelah
13
Apr 12, 2009 08:34 PM
machinist man
1997 - 2003 F150
Jul 13, 2006 07:19 AM
skips69
Jun 9, 2004 04:35 PM
