Where is the sticker with the calibration number for the PCM located? It's on the driver's side door jamb on my Ranger, but I looked there on my 02 F150 and all that's there is the VIN sticker. I also looked under the hood, and all I saw was the engine ID sticker on the driver's side valve cover. Anyone know?
Your 02 will be on the passenger side door jam due to the fact your PCM is located under the kick panel on that side. I had the same problem when lookin for it also because my previous truck was a 95 which had the PCM under the drivers kick panel, hope this helps.
LxMan,
The sticker on the valve cover is as follows:
2G876AA
(Bar code)
012400023
522 08-28-01 54L
I know the 8-28-01 is the build date and the 54L is the displacement, but I'm not sure what the other numbers are.
xtrford,
On the passenger side front pillar where the door hinges are, there is a sticker with a 4-digit number, it's WUQ3. Is that the calibration number?
