hydraulic roller cams
Old Mar 22, 2007 | 06:56 AM
lucky no. 7's Avatar
lucky no. 7
just have a couple questions on hydraulic roller cams for th 400 motor, first off, i know you can use a cleveland cam in em, but what lifters do ya use, i think i've only seen one set that crane or comp makes but them damn things are like 500 bucks, is there an alternative to these, also what do you do about pushrods,
Old Mar 22, 2007 | 10:50 AM
beartracks's Avatar
beartracks
I believe all those cams were developed for 351C's. However they work good in a 400. I have a Crane set up. You need the cam, lifters pushrods, adjustable rockers (rollers) and push rod guide plates. It can be expensive and you need to be very carefull of the valve train geometry being correct. That being said I love the characteristics of the cam.
Old Mar 22, 2007 | 10:59 AM
lucky no. 7
well i have the guideplates and rockers and alll already, do you recall what pushrod legth you used on the ole 400, this is a motor thats goin together for a daily driver, a 72 f-100 short bed, i'm just kinda weighin options right now as i have already bought a hydralic flat cam for it pn 133042 crane, got pretty much everything to put him together except an oil pump and the time, as i am in baghdad for another 6 months, pretty much my inspiration to come home is that ole motor runnin
Old Mar 22, 2007 | 06:31 PM
Torque1st's Avatar
Torque1st
Posting Legend
The hydraulic flat cam will not work with roller lifters.
Old Mar 23, 2007 | 07:06 AM
mark a.'s Avatar
mark a.
Push rod length can vary from motors when you are changing things and doing machine work. You will need to check yours to be sure what you need.
Old Mar 23, 2007 | 09:49 AM
beartracks's Avatar
beartracks
Roller cam and roller lifters are two different critters.
Old Mar 23, 2007 | 10:05 AM
xlman's Avatar
xlman
Lucky No. 7, being a Vet (1973) jus' wanted to say "thanks for your service and hope you make it home to your truck OK" !!
Old Mar 23, 2007 | 08:14 PM
danlee's Avatar
danlee
Comp Cams makes a roller cam conversion kit that you can use. It allows you to use roller lifters from a 5.0 Windsor roller motor in a non-roller motor. It will work on a 351C or 351M/400. Roller lifters for a 5.0 are much cheaper than aftermarket roller lifters.
Old Mar 26, 2007 | 09:10 AM
beartracks's Avatar
beartracks
I had meant to say roller cams/lifters vs roller rockers are two different things.
beartracks
Jan 28, 2017 07:06 PM
400inatruck
Jan 29, 2013 05:57 PM
LindenBruce
Mar 10, 2010 08:57 AM
apachetech
Jan 24, 2007 08:30 PM
RapidRuss
35
Nov 30, 2006 06:14 AM
