Sponsored by: Real Truck
Blown relay?
Old Mar 21, 2007 | 03:56 PM
BBBRIG4451's Avatar
BBBRIG4451
Blown relay?
I was installing my car alarm today, and i accidently plugged the headlight swith (it was turned to the on position) into the truck with the battery attached. It blew a fuse, and after there was a vibrating sound that occured about every 10 seconds behind the middle of the dash. After about 10 minutes of the vibrating sound, it smelt like something was burning, the vibrating sound went away, but the instrument lights still dont turn on (ALL OTHER LIGHTS WORK) im assuming i blew a relay but i dont know...any suggestions???
Old Mar 22, 2007 | 07:46 AM
rwilimo's Avatar
rwilimo
Plugging in the headlamp switch would not cause any of the described problems. I would look carefully at what connections you made with your alarm, as chances are that is the cause. Perhaps you sent ground or power to the wrong circuit in the truck.
Old Mar 22, 2007 | 12:47 PM
johnnysF350's Avatar
johnnysF350
I believe the Lighting Control Module is up there in the center of the dash. I dont know if it has any serviceable relays in it. Sure sounds like you fried something in it though. I have to agree with rwilimo. Double check that all your connections were correct. I'm sure a couple of them were made into the vehicles lighting circuits. Check other fuses too, as the instrument lights might be fused on a seperate circuit than the blown fuse you found.
eff two fifty
Dec 4, 2019 06:51 PM
BBBRIG4451
Apr 2, 2007 12:54 AM
Mid_Mo_F100
Dec 16, 2006 07:58 PM
mpbpulaski
Oct 27, 2004 11:14 PM
