vibration after Tymar intake install
Old Sep 14, 2004 | 07:30 PM
mpbpulaski's Avatar
mpbpulaski
I just installed a Tymar air intake on my '02 crew cab dually. As soon as I hopped in to test drive it, I noticed a vibration through the brake pedal. This is in park as well as when stopping at a light.
I double checked that everything was tight and installed properly. The truck seems to run fine and sounds the same except for the extra whine from the intake.
Any suggestions as to the vibration? Anyone else noticed this?
Old Sep 14, 2004 | 09:48 PM
Bob Goodsell's Avatar
Bob Goodsell
Is the filter touching the master cylinder? It's a close fit but you can bend the bracket a little to keep the filter away from the master cylinder.
Bob
Old Sep 15, 2004 | 07:36 PM
mpbpulaski's Avatar
mpbpulaski
Yes, the filter is touching the lower part of the master cylinder - I will move it tomorrow and see if that takes care of it.
Thanks.
Old Oct 26, 2004 | 08:09 PM
whphel's Avatar
whphel
So did that suggestion help with the problem? I just installed one myself and all the sudden, I have the same issue and would like to know if and what you did to fix it.
Old Oct 26, 2004 | 10:17 PM
Kwikkordead's Avatar
Kwikkordead
What Bob Goodsel said, if you are feeling something new through the brake pedal, then take whatever steps are necessary to isolate the contact points from the master cylinder and related assemblies. Bend tabs, cut away something on the new kit.
Old Oct 27, 2004 | 11:34 AM
Les100's Avatar
Les100
Question Brake pedal vibration
I was feeling the same vibration after I installed the 6637 filter. I think the only way to get the filter away from the master cylinder is by adding a 45 degree bend 4" tube. Kwik, what do you think.
Les
Old Oct 27, 2004 | 04:10 PM
mpbpulaski's Avatar
mpbpulaski
I had to take the battery back out and loosen the bracket bolts to turn it just slightly.
I got the filter off the master cylinder (barely) - problem solved. It is a tight fit.
Old Oct 27, 2004 | 11:14 PM
Kwikkordead
Les
I went out and looked at my truck and didn't see any room for adjustment anywhere. The filter was resting against the battery box on one side and the relay box on the other side. For some reason my filter is VERY CLOSE to the master cylinder but not making contact anywhere. You might try loosening the clamp that holds the intake boot to the CCV stand and rotating the assembly a bit to try and get the air cleaner to sit up at a slight angle and clear the master cylinder. Other than that there is simply no room for front to back adjustment. At least on my truck there isn't. I put a new picture in my gallery if you want a better view. You can see that it's tilted when it's sitting in the truck.
sbraatz
Nov 9, 2007 05:27 PM
the weez
Jun 18, 2006 03:14 PM
stroker250
Jun 30, 2005 12:11 PM
ltfox
23
Apr 26, 2004 10:58 AM
spitball
Mar 22, 2004 11:57 AM
