Deisel fuel problem ... [HPOP] ?
Old Mar 20, 2007 | 07:56 PM
firewoodguy221's Avatar
firewoodguy221
My 1999 F 350 wont start . Occasionally it will fire up and run very well for about one minute [usually after it sat all night]
It has good fuel delivery and there is no air in the line [no bubbles in clear fuel test hose ] There's no restrictions in the lines . I changed the oil ,oil filter and fuel filter .The glow plugs work and the injector harness is fine
The engine valley radically filled with oil once [about a month before this began happening ] It mysteriously stopped leaking and ran fine until turned it off two weeks ago Ive been working on it ever since...Money is a problem and its stuck in a bad spot .
this is my first deisel. I've never had a problem diagnosing any mechanical issues....Until now
Old Mar 20, 2007 | 08:16 PM
Pocket's Avatar
Pocket
Did you check your oil level?
Also a bad CPS can cause the truck to shut off.
Old Mar 20, 2007 | 08:25 PM
firewoodguy221
hpop oil level is fine
how do i check cps
Old Mar 20, 2007 | 08:55 PM
kennedyford's Avatar
kennedyford
Oil can be from the injector pressure regulator (ipr), oil line orings or the turbo o-rings. You need to clean that valley, fill the truck with the correct oil levels especially the hpop recheck before cranking. You will then need a friend to help you crank without cutting your fingers off. My primary thought is the oring on the ipr let go or the ipr is loose. Ill try and find a pic, its been posted many times here.
Old Mar 20, 2007 | 09:12 PM
kennedyford
Found it in another posting. Common dirty problems, low cost items from International NOT FORD.
https://www.ford-trucks.com/forums/3...sure+regulator
Mr. Finch
Mar 29, 2012 06:37 PM
Daveyf15096
Jun 25, 2011 05:51 AM
pdqtimetrialer
Modular V8 (4.6L, 5.4L)
Nov 28, 2005 04:48 PM
Squiggy
Oil & Lubrication
Mar 14, 2003 12:44 PM
TORCH
Jan 1, 2002 10:39 PM
