Dome light wiring
Old Mar 18, 2007 | 09:43 PM
cbfomoco's Avatar
cbfomoco
Dome light wiring
When i put in a new wiring harness I want to get the dome light working. I know that it runs from the headlight to the dome light. My question is there anyway to wire it up so that it will turn on with the head light swithc and turn on when the door opens? I know that I need switches to the door post but after that I am lost. thanks
Old Mar 18, 2007 | 10:29 PM
Haaser's Avatar
Haaser
This is actually pretty simple. Run a constant hot wire with a fuse to the door post . Then run it to the wire going to the dome light. As long as you dont have the door open and the dome switch on the light, will never have any issues.
Old Mar 18, 2007 | 10:31 PM
Haaser's Avatar
Haaser
Just splice into the wire on the headlight switch too. It would be super simple with very little wiring.
Old Feb 22, 2013 | 11:08 AM
reddnekk's Avatar
reddnekk
66 F100: The wire for my dome light is hanging under the dash. It works when wedged into the fuse box. Of course it won't stay. Where should I connect it?
Old Feb 23, 2013 | 11:36 AM
KO1960's Avatar
KO1960
The dome light is powered from the headlight switch. The wire color should be black-blue. Search previous posts, and you may find the diagram you need or get yourself a wiring diagram. Only about $7. Good luck.
Kurt
Old Feb 24, 2013 | 06:22 AM
reddnekk's Avatar
reddnekk
dome light
I think thats all I needed to know. I assumed the dome light would stay on when the head lights are on. Don't know if I can turn the **** left to click it on or not. It should. Thanks.
jatimmons
Jan 13, 2017 08:07 AM
mrstephs
Apr 16, 2016 08:13 AM
Doubleubar
Feb 24, 2016 06:33 AM
BLACKHAWK_1989
Jan 7, 2016 09:42 PM
Andrew010
6.7L Power Stroke Diesel
Sep 12, 2012 07:51 PM
