p1316 problems
Old Apr 15, 2007 | 11:06 PM
  #31
mylakers's Avatar
mylakers
Ran compression test on all cylinders:
7=200 8=100
5=320 6=320
3=320 4=320
1=320 2=320
Put about tblsp of oil in 7 and 8 and reading went up 100psi in each. Can it be anything besides the rings? If it is the rings can I fix it without pulling the motor,possibly pulling heads and oil pan and changing rings? Last thing is What caused this?
Thanks for everything
Tom
Old Apr 16, 2007 | 12:08 AM
  #32
kennedyford's Avatar
kennedyford
Are you pulling the compression test from the glow plug fittings? Possible problems with the copper washers and orings on the injectors and leaking back? 16 dollars to fix that if only.....
Old Aug 27, 2007 | 10:31 PM
  #33
mylakers's Avatar
mylakers
Final report: had to rebuild entire engine and turbo previous owner must have put alot of miles on it with a broken air filter box. Had to re-sleave motor due to 6,7,8 cylinders being to far gone to bore. Motor is back in and running. I am still getting the p1316 code cylinders 1-5 high to low side open. What else can it be I have new glow plugs and wiring harness but did not replace the injectors.
Thanks for all the help, Tom
Old Aug 27, 2007 | 10:44 PM
  #34
Tenn01PSD350's Avatar
Tenn01PSD350
Man, that has been a long tough road. I will skip any comments on the rebuild vs a replacement and ask, how is the truck running now?
Old Aug 27, 2007 | 11:14 PM
  #35
mylakers's Avatar
mylakers
Seems to run great except I still get the P1316 code and it has a new uvc harness already. Has me stumped.
Old Aug 27, 2007 | 11:21 PM
  #36
Tenn01PSD350
Have you tried clearing it?
Old Aug 28, 2007 | 08:43 AM
  #37
Kwikkordead's Avatar
Kwikkordead
Seems like the only thing left is the IDM, unless two injectors are bad.
I would suspect the IDM first due to the law of averages.
Old Nov 8, 2007 | 08:03 PM
  #38
mylakers's Avatar
mylakers
Turns out I changed the IDM and still had problems. Then had 7 injector codes changed out all 8 with reman. from Pensacola Diesel Inc. at $99 each and they dont care about the cores as long as they are fresh out of a truck and not physically damaged. I sent them 6 AD and 2AB injectors and everything is great so far. Thanks for everyones help it was greatly appreciated.
Tom
Old Nov 10, 2016 | 10:57 AM
  #39
DGA-5 MIKE's Avatar
DGA-5 MIKE
I am getting a P1316 code, but my 2000 F250 is running great. What values for the Ohm's should I be looking for when I check the wiring harness?
Old Nov 10, 2016 | 09:50 PM
  #40
cps's Avatar
cps
Go to GB remanufacturing website. All the info you need about the IDM and wiring and troubleshooting.
Roy
Old Nov 11, 2016 | 11:04 AM
  #41
DGA-5 MIKE's Avatar
DGA-5 MIKE
P1316
Roy,
thank you for the website, but I can't seem to finfd the troubleshooting site for my year/make/model of truck. Any hints where I should look?
Thanks
Old Nov 11, 2016 | 05:13 PM
  #42
cps's Avatar
cps
When you are on the home page, click on "techblog". On the right hand side of that page there is 7.3 info that should help you.
henrymiller1
Nov 18, 2017 06:52 PM
Bvill01
17
Oct 15, 2017 10:37 PM
stef67
New Member Introductions
Jun 12, 2017 10:02 AM
jstihl
May 27, 2016 06:30 AM
Johnmc
Apr 14, 2016 10:10 PM
