Ford F250 rear diff fluid type/amount
Old Mar 16, 2007 | 09:13 PM
John311t's Avatar
John311t
When i changed my fluid, i did not add any friction modifier. The LSD still works, and i do not get chattering or any wierd noises at all. Is there any problems with this or should i go ahead and add the modifier because i thoguht the modifier just helped with noise?
Old Mar 16, 2007 | 10:16 PM
ernesteugene's Avatar
ernesteugene
What is the correct amount of friction modifier?
Cgl posted....... Be sure to add 8 oz. of Additive Friction Modifier (Ford Part Number XL-3)
KrenzyRyan posted.......4 oz of Ford's XL-3 Friction Modifier
My owners manual says 8 oz per 3.5 qts, but my Mag-Hytec says 4 oz for 3 qts?
Maybe they don't lock up so well if 4 vs 8 is correct and we put in X2 too much?
Old Mar 17, 2007 | 07:05 AM
DISLFVR's Avatar
DISLFVR
Locomotive breath
I'm in need of replacing the cover on mine and plan on one of the Oasis covers and Royal purple fluid, how much modifier to add??? Any thoughts? Or add till it quits chirping in tight turns. Thanks guys
Old Mar 17, 2007 | 07:31 AM
Uzumati's Avatar
Uzumati
With Royal Purple Max Gear add 0.00000 oz of friction modifier. Its already in there
Ernest after finding the 3rd different capacity in a 3rd different manual I switched to the RP and havent worried about it yet
Old Mar 17, 2007 | 08:04 AM
DISLFVR's Avatar
DISLFVR
Locomotive breath
[QUOTE=amiller93]With Royal Purple Max Gear add 0.00000 oz of friction modifier. Its already in there
Thanks, I remember reading somewhere on here about it but was'nt sure.
Old Mar 19, 2007 | 08:24 AM
mdevers's Avatar
mdevers
Not sure if this is true or not but I heard that your mess with the aggressiveness of the limited slip by adding less friction modifier,I know that to little could over work clutches. I would like mine to lock faster.
Old Mar 19, 2007 | 11:22 AM
ernesteugene
So, how much is in the Royal Purple you now use? Is there a down side to using too much besides the lock up not engaging? I would just as soon have a non-limited slip anyway.
Old Mar 19, 2007 | 12:22 PM
cgl's Avatar
cgl
...Ernest after finding the 3rd different capacity in a 3rd different manual I switched to the RP and havent worried about it yet
I've even seen two different quantities in the same manual (4oz and 8oz). I added 4oz (1 bottle) and have had no problems. My service guy says thats all he adds to his own vehicles.
woody367
Nov 13, 2016 12:09 PM
woody367
Nov 13, 2016 11:12 AM
Littlemonster250
Sep 29, 2016 10:56 PM
86f250xl
Large Truck
Jul 7, 2015 05:33 PM
ALF1999
May 14, 2005 03:44 PM
