Ford F250 rear diff fluid type/amount
Old Mar 16, 2007 | 06:42 PM
ro1bvan1's Avatar
ro1bvan1
What type and how much fluid does the a 2001 F250 use? Thanks
Old Mar 16, 2007 | 06:50 PM
Uzumati's Avatar
Uzumati
373 gears with limited slip? that would be 7 (8.5 is wrong) pints 75W140 with friction modifier
Old Mar 16, 2007 | 06:52 PM
ro1bvan1's Avatar
ro1bvan1
yes 3.73 gears but the limited slip really doesn't work.
Old Mar 16, 2007 | 06:53 PM
cgl's Avatar
cgl
For a F-250 / 350 with the 10.50 inch axle, you need...
3.5 quarts (= 6.9 pints) of Motorcraft SAE 75W-140 High Performance Synthetic Rear Axle Lubricant (Ford Part Number XY-75W140–QL)
It runs about $10 a quart from the dealer.
Be sure to add 8 oz. of Additive Friction Modifier (Ford Part Number XL-3) if you have a Limited Slip differential. Noticeable if you have a L (ie. 3L73 or 4L10) in the ratio on the housing tag.
Old Mar 16, 2007 | 06:54 PM
kennedyford's Avatar
kennedyford
So you say. Mine is new and it doesnt feel like it works either. The guy that rebuilt mine says the only difference of our and the ol 80s style is the disk brakes and the fact they put in synthetic.
Old Mar 16, 2007 | 06:58 PM
cgl's Avatar
cgl
Originally Posted by amiller93
... that would be 8.5 pints 75W140 ...
This is true, if you have a 350 DRW with the Dana 80.
Old Mar 16, 2007 | 07:00 PM
Uzumati's Avatar
Uzumati
cgl is right it is 7pints I copied and pasted from the wrong line, also this note in the manual
Service refill capacities are determined by filling the axle to the bottom of the filler hole. On Traction-Loc® axles, always add friction modifier first.
Old Mar 16, 2007 | 07:01 PM
clintbonnie's Avatar
clintbonnie
My manual says if you have a Dana 80 to use 75W90 Premium "Synthetic" lubricant along with the friction modifier. If you have Dana 135 to use 80W90 Premium lubricant along with the friction modifier. I guess the "Ford" rear in, use the 75W140 High performance synthetic along with the friction modifier.
Old Mar 16, 2007 | 07:04 PM
cgl's Avatar
cgl
...also this note in the manual
GOOD POINT!!! This is a definite MUST DO!
They must've changed that for the MY2001 Super Duties. The 01 manual states 75W140 Synthetic for 10.5 & Dana 80's and 80W90 Premium for Dana 135 (F-550)
Old Mar 16, 2007 | 07:18 PM
Izzy351's Avatar
Izzy351
My limited slip seems to work -- when I break loose I get both rear tires leaving marks, not just one. Limited slip on my 'stang was the same. My Ranger was a non-limited slip and it was definitely a one-wheel-peel truck...
Joe
Old Mar 16, 2007 | 07:23 PM
Izzy351's Avatar
Izzy351
BTW, there's a site someplace that has a good description on how to do the fluid change on the rear-end... Can't remember off the top of my head, but I'll bet someone knows it.
Old Mar 16, 2007 | 07:36 PM
Uzumati's Avatar
Uzumati
This one http://guzzle.rbmicro.com/rdiff.html
Old Mar 16, 2007 | 07:45 PM
Izzy351's Avatar
Izzy351
That's the one I was thinking of... You rock!
Old Mar 16, 2007 | 08:15 PM
KrenzyRyan's Avatar
KrenzyRyan
Quoting from Guzzle: "The Sterling 10.5 will require 6.9 pints (3 1/2 quarts) of synthetic 75W-140 gear oil and if yours is a limited slip differential, pickup 4 oz of Ford's XL-3 Friction Modifier."
How exactly do you know if your is limited slip?
Old Mar 16, 2007 | 08:20 PM
Uzumati's Avatar
Uzumati
The code on the tag on the rear diff an "L" in the lower left number on the tag denotes it
