front end alignment
Old Mar 16, 2007 | 10:28 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Mine was unbolt, swap and rebolt. Simple swap, great results.
The price was steep, but since I have already saved 800 plus dollars on tires, I think I will recoup the cost in a couple more years and be dollars ahead.
Plus the traction lock has already made me much happier and the truck muck more unstoppable out in the mud.
Win win for me.
You need the axle and steering linkage, you also have to remember what it came out of when you need parts for it.
I walk around with a list of what truck model and year several of my parts came from already, mine is somewhere between a 1985 and 2002 F250, F350 or F450 with a 6.9, 7.3 or 7.3 turbo motor if I were to get technical about it.
Old Mar 17, 2007 | 03:26 AM
fonefiddy's Avatar
fonefiddy
Now that is funny. They outta call you Dr. Frankenstien
If it were me, I'd replace everything while under there. From the ball joints to the pitman arm. When you take it in for alignment, 99% of the time the tech will come out and tell you they need replacing in order for him to "get it right"
At LEAST, I'd replace the tie rod ends, when doing ball joints.
I had a differnt experiance with Ford service. The tech had the camber cones, but said it was pretty close, and I should be allright. 20K miles later and my tires are wearing to the inside. GRRRRRR. When I did a complete rebuild of the 85 2WD, I took it to a place that does everything from cars to semi's. They had a rack on the wall with 20-30 Ball joint camber cones on it. I wish I'd have taken my 4x4 there.
Old Mar 17, 2007 | 11:25 AM
Dave Sponaugle
I do have a rather good dealer close to me.
Any of the chain alignment shops here have no problems with a two wheel drive, but they want nothing to do with a 4x4 camber or caster adjustment.
The techs at Ford had no problem with either adjustment on both the original 44 or the replacement 60 I put in.
I really get a kick out of my 86 Ford with over 300,000 miles on it drives better than either a 2003 Ram 3500 or a 2000 Ram 2500, both of them are 4x4.
Several of the guys I work with have driven all the trucks listed, they all like mine better except for the actual Dodge owners. Or maybe they just will not admit what the others all say is true.
Old Mar 17, 2007 | 01:17 PM
speedrdr's Avatar
speedrdr
thanx dave, what i was hoping to hear. glad it's reasonably simple to do. i'm assuming that break calipers, lines, all that good stuff is in same hook points on 60?
speedrdr
Old Mar 17, 2007 | 03:02 PM
Dave Sponaugle
Actually I could have used my 44 calipers, they would have clipped right in.
If you happen onto a 70's model 60 it is not as easy and they used king pins instead of ball joints.
Also I forgot to mention you need the trac bar and mounting bracket for it.
You also need to remove a couple brackets that the IFS mounts to now.
It does take a little time, but it is still a bolt out, bolt in swap.
Old Mar 17, 2007 | 03:42 PM
speedrdr's Avatar
speedrdr
thankx. have starting place and know end is in sight, thanks to help from FTE and its members! this is the best site anywhere
speedrdr
Old Mar 17, 2007 | 05:24 PM
Barehuggs's Avatar
Barehuggs
Hmmm Sounds like a Johnny Cash Song to me
Old Mar 18, 2007 | 03:16 PM
dwkremer's Avatar
dwkremer
As mention changing the ball joints requires you to pull the axel drive shafts. Be extra carefull when you remove them that you do not nick the differential seal.
speedrdr
Apr 1, 2009 05:39 AM
speedrdr
Feb 21, 2008 10:01 PM
speedrdr
16
Nov 25, 2007 01:20 PM
speedrdr
Jul 20, 2007 11:08 AM
speedrdr
32
Mar 14, 2007 12:03 AM
