Loud Tick
Old Mar 17, 2007 | 12:43 PM
DieselRunner's Avatar
DieselRunner
Loud Tick
So the other day it was sunny out so i had my windows down and my split window open. Im driving along enjoying the weather and then i start to notice a pretty loud ticking sound comming from what seams to be the rear end on the truck. It only happens once in a while but it only happens when starting from a stop. Ive only noticed it when starting from second gear. And its only one loud tick, like a metal on metal tick, or click. Also its not when the truck starts rolling. its between starting the roll and compleatly off the clutch. So from the drivers seat it sounds like it could be comming from anything from the trans back. Im leaning more towards clutch related but i just hope its not my rear axle. Any thoughts and ideas for trouble shooting would be really appreciated.
Thanks in advance.
Truck is 1991 F-250 EXt cab 7.3L 2WD ZF-5, 3.55 rear axle ratio, 317500K
Old Mar 17, 2007 | 03:27 PM
KJLYPW's Avatar
KJLYPW
Most often this type of noise ends up being a worn universal joint on the drive shaft in my experiance.
Old Mar 17, 2007 | 07:22 PM
brownieboy525's Avatar
brownieboy525
i am with KJLYPW on thiis that it is probably a u joint. when my were bad when ever i put the truck in get it banged when ever i let off then gassed it again it bagged and when it shifted. try to rotate the drive shaft when its in gear to see if there is any play in it
Old Mar 17, 2007 | 09:30 PM
Dave Sponaugle's Avatar
Dave Sponaugle
I also agree on the U joint, but also check the carrier bearing.
Old Mar 17, 2007 | 10:47 PM
DieselRunner
Alright, Thanks guys.
how much play is exceptable?
Alos dave, Carrier bearing?
Old Mar 17, 2007 | 11:26 PM
Dave Sponaugle
In the U joints, none.
If the U joint cross moves in relation to the cap you have found your bad universal.
You list an extended cab, it should have a two piece driveshaft with a carrier bearing located on a cross member at the back of the cab.
Old Mar 17, 2007 | 11:35 PM
DieselRunner
Oh thats what that is, right on then. Thanks alot!.
Old Mar 18, 2007 | 10:12 AM
PLC7.3's Avatar
PLC7.3
DR ........dont forget to mark all the parts for alignment before disassembly.
Old Mar 18, 2007 | 10:38 AM
PlaidassSurf's Avatar
PlaidassSurf
i just replaced my u-joints, heard that clicking noise, got anotherneath the truck and wiggled the driveshaft and it moved from side to side. i was missing half the needle bearings
Old Mar 18, 2007 | 11:39 AM
DieselRunner
where is the best place to get replacment u-joints? could i do it myself or should i take it in?
Old Mar 18, 2007 | 01:44 PM
brownieboy525
i got mine at napa i would get the ones that are greasable. i think they were like $25 for each. they are pretty simple to change
Old Mar 18, 2007 | 04:15 PM
DieselRunner
ok right on man, thanks.
TrukProblemz
2004 - 2008 F150
Feb 10, 2014 02:51 PM
JamieMueller
Modular V10 (6.8l)
17
Sep 13, 2011 07:01 PM
kper05
6.7L Power Stroke Diesel
Sep 11, 2010 10:55 PM
dderek
Modular V8 (4.6L, 5.4L)
Jul 9, 2007 01:32 AM
seebeew
Exhaust Systems
Sep 5, 2001 03:36 AM
