ignition switch sticky
Old Feb 21, 2008 | 12:39 AM
speedrdr's Avatar
speedrdr
quick question. i know it's probably been covered, but can't find the thread-don't know how to search for it. got a new ignition switch in steering column. key works fine but when you turn the switch it's real stiff and don't act like it's going far enough over to work right. do i need to replace the actuator rod that's in there or if it's bent can it be straightened without breaking?
speedrdr
Old Feb 21, 2008 | 12:58 AM
PLC7.3's Avatar
PLC7.3
When you assembled the switch etc did you ensure the lock gear drive was positioned same as when removed....
The position of the the lock drive gear is correct if the last tooth on the drive gear is meshed with the last tooth on the rack.
Old Feb 21, 2008 | 10:01 PM
speedrdr's Avatar
speedrdr
didn't check, but will. wasn't paying close enough attention. something about following instructions???? thanks, plc7.3
speedrdr
speedrdr
Apr 1, 2009 05:39 AM
speedrdr
15
Jul 4, 2008 11:25 AM
speedrdr
16
Nov 25, 2007 01:20 PM
speedrdr
Jul 20, 2007 11:08 AM
speedrdr
22
Mar 18, 2007 03:16 PM
