1978 - 1996 Big Bronco
High output alternator
Old Jun 28, 2002 | 05:30 PM
nv_brewer's Avatar
nv_brewer
I want to install a high output alternator but an leaning away from the Mustang 3G since it's idle output is ~20A. I read that an '86 Taurus unit was installed using a bracket from a company no longer in business.
Any comments on an alternator that has a high idle output and will drop in a '91 351W?
Old Jun 29, 2002 | 11:19 AM
restorit's Avatar
restorit
No guarantees, but you might try checking on the alternator from a van of your year and engine. Because a lot of the E-150's saw customizing, with lots of power options, some had some pretty big alternators. For example, my truck came stock with a 65 amp alternator. I was able to purchase a 100 amp unit for an E150 of the same year and engine (302). It should bolt up based on my check of the measurements (though I haven't installed it yet.... engine is being pulled for a rebuild). The alternator is physically larger, but the 65 amp brackets should still allow it to fit. I will have to make some changes to the wire connectors, but that should be it. Hope this helps!
Old Jun 29, 2002 | 06:11 PM
AlM's Avatar
AlM
yo,
mudman says he got a 130a alt from a diesel truck for his 93:
http://users.superford.org/mudman/
see his home page for an e mail link (hope he doesn't mind)
Old Jun 30, 2002 | 05:53 AM
wayne_j's Avatar
wayne_j
mattymax
Dec 5, 2015 10:47 PM
Tyler.172
Aug 22, 2015 11:59 AM
bert cook
Jun 4, 2015 05:17 PM
Totally Tuna
Aug 1, 2014 01:55 PM
counciller
Apr 17, 2014 09:18 PM
