high output heaters??
Old Jun 3, 2015 | 08:53 PM
bert cook's Avatar
bert cook
i know that the dents and the bulls had high output heaters that could be ordered was it an option for the bumps?
Old Jun 3, 2015 | 09:11 PM
ultraranger's Avatar
ultraranger
If the question is in reference to a Bumpside truck, you can take a blower motor from an '84-'86 Jeep Grand Wagoneer, pair it with the larger squirrel cage fan from a Dentside truck and install them inside the Bumpside heater housing, for much greater output.
Supercharged Heater Fan Upgrade - The FORDification.com Forums
Old Jun 4, 2015 | 05:36 AM
willowbilly3's Avatar
willowbilly3
I don't think it was an option until 73. I drove a 72 for many years in Akasja and never felt the heater wasn't good enough. If it's all in proper working order and the cab is tight, no problem staying warm at 25 below. I used to run a 205 thermostat and you could hardly hold your hand over the defroster.
Old Jun 4, 2015 | 12:14 PM
JEFFFAFA's Avatar
JEFFFAFA
2X. Ford only lists one non-A/C heater core and one non-A/C blower motor.
Old Jun 4, 2015 | 05:17 PM
MIKES 68 F100's Avatar
MIKES 68 F100
That works ? more CFM would mess up the heat transfer from coil ,
This is why your home Furnace motor is on low speed and the AC circuit runs on the motors high speed .
F250army45d
34
Nov 27, 2008 11:33 PM
balingwire
Feb 21, 2008 03:59 PM
Frank Lang
Feb 28, 2005 02:38 PM
natecousineau
Nov 7, 2004 01:28 PM
biggreen4x4
51
Dec 16, 2003 01:22 PM
