1978 - 1996 Big Bronco
'92 Bronco tailgate window dash switch
Old Jun 9, 2002 | 06:08 PM
wldavis's Avatar
wldavis
Post '92 Bronco tailgate window dash switch
Bronco owners,
Can anyone tell me how to remove the tailgate
window dash switch to clean the contacts?
Thanks, Bill
Old Jun 9, 2002 | 07:04 PM
AlM's Avatar
AlM
yo,
Look here at Dustin's site for how to (skip the wiring harness step, etc.):
http://users.superford.org/ylobronc/tailgate/tailgate.html
Old Jun 11, 2002 | 08:23 AM
wldavis's Avatar
wldavis
Al,
I read over Dustin's tech story as
to replacing the tailgate on his Bronco,
but I saw nothing about the dash-mounted
window control switch.
Is there any other site you can send me to?
-Bill
Old Jun 11, 2002 | 10:45 AM
90EBBronco's Avatar
90EBBronco
Pull the dash panel off and disconnect the switch. It should be very easy to open up the switch once it is removed. If your switch isn't working it is probably because they were made very poorly. I opened mine up and soldered the contacts together so I could at least open the window from the back. If your contacts don't mate right in the front your rear taigate switch won't operate the window. Good Luck!
KJ
Old Jun 11, 2002 | 03:16 PM
AlM's Avatar
AlM
90 eb, thanks dude for giving him the right info! I missed the dash part..Im too messed up to get thAngs right..
wldavis; here is some info on getting that panel off (not the gauges):
https://www.ford-trucks.com/dcforum/DCForumID39/4412.html#2
Old Jun 26, 2002 | 12:00 PM
CityBronco's Avatar
CityBronco
Old Jun 26, 2002 | 09:02 PM
wldavis's Avatar
wldavis
Al,
Thanks for giving me the link to dash removal
on the Bronco. This helped us to get to the
dash switch. It was the dash switch that was
not making good contact and we got it fixed.
Thanks again,
Bill
Old Jun 30, 2002 | 08:53 AM
wisdom565's Avatar
wisdom565
There are two silver trim strips on the dash next to the vents. Remove those carefully with a flat screw driver. There will be two small bolts underneath. remove those. Next, remove the headlight switch **** using a small flat screw driver by putting the screwdriver in the slot (you may have to turn on the headlights and rotate the **** to find it) and pull towards you. The dash is removable now and you have access to the wires for the tailgate switch and electronic 4 wheel drive switch (if equipped). I would suggest dropping the tilt wheel all the way down and putting the key in to bring the gear lever all the way down. This makes it easier. Also note that the switch is about $21.00. I just replaced mine.
Before getting too far, let me ask you, Does the key switch work on the tailgate itself? If not, you may have a wiring problem. Each switch needs the others wiring to work. Both switched when not activated are in the ground position and have their own power supply. If the rear switch works, then the dash probably needs a simple replacement described above..
78Ranger_Bronco
33
Oct 2, 2018 08:05 PM
kirby1111
Mar 16, 2016 09:10 AM
TicoTube
19
May 3, 2013 03:03 PM
mikeismadness
21
Jul 27, 2011 02:29 PM
Castoff52
16
May 22, 2003 10:57 AM
