water pump and alternator replacement
Old Mar 14, 2007 | 12:55 PM
bc30629's Avatar
bc30629
I have a 95 F-150 with the straight six in it but i haven't driven it for a long time. I just started it up today and found that my altenator and water pump are seized up. I hired a local traveling mech to come fix it for me but i was unsure of what the parts pricing for these two pieces would be? He is doing the work for cheap as far as labor goes but i dont want to get screwed in the parts area. Thanks for the help!
Old Mar 16, 2007 | 08:16 AM
ubereal2's Avatar
ubereal2
Are you sure the waterpump and alternator are locked up and not the motor?
Old Mar 16, 2007 | 09:56 PM
bc30629's Avatar
bc30629
Yeah... engine starts fine
Old Mar 17, 2007 | 02:00 PM
optikal illushun's Avatar
optikal illushun
i dont see how the waterpump could juse sieze up...alternator...yes. smog pump, yes.
either of those are a simple fix, u could easily do them urself. how do u know both are seized?
Old Mar 17, 2007 | 02:10 PM
bc30629's Avatar
bc30629
Well i know that the alternator is seized because the pulley will not turn at all. There is no serpentine belt on the vehicle so i can just grab hold and try to turn it. Its locked tight. I was told the other pulley that wont move is connected to the water pump. Now im not too sure that it is the water pump, but it is the pulley directly underneath the alternator. This one as well will not turn when i grab a hold and turn it. If it is not the water pump then can someone please update me with what it is. Also, i have been talking to a traveling mech to come fix it but if its an easy job i am always willing to get my hands dirty. Thanks for the help.
Old Mar 17, 2007 | 02:11 PM
optikal illushun
the one below the alternator is indeed the smog pump. both are easily replaced.
Old Mar 17, 2007 | 02:13 PM
bc30629's Avatar
bc30629
fantastic, can you give me a quick list of tools i might need to complete this job and maybe a brief on how to actually do it?
I have a subaru WRX as well and im just starting to get into my own mechanic work, so this should be a good project to get me started.
Old Mar 17, 2007 | 02:16 PM
optikal illushun
i dont remember the exact bolt sizes but nothing more than some standard and metric sockets and wrenches (these trucks are horrible for having mis-matched bolts).
the altnerator comes off with two bolts and removal of the wiring harness and charge wire. the smog pump is a little harder (accessability is tight, better off doing this after the alt is off). but the same thing applies here as well, just two or three bolts the pulley then the retaining bolts (similiar to the alt.)
a prybar is a good idea to help pursuade the parts out. spray everything up with some PB blaster a few hrs before and it should go pretty easy. i think thats it, if not, its not much more involved. thankfully Ford made these trucks easy to work work on.
Old Mar 17, 2007 | 02:34 PM
bc30629's Avatar
bc30629
thanks a bunch, thats gonna save me another hundred in labor charges. My best bet to call my local yard for the parts? Or is there anywhere online i can get some cheaper?
Old Mar 17, 2007 | 02:41 PM
optikal illushun
that i cant help ya with, sorry.
Old Mar 17, 2007 | 05:14 PM
bc30629's Avatar
bc30629
haha, right... should have known that was coming. So anyways, im gonna call my local yard and autoparts dealer and see what i can pull from the muck. Thanks for the help, i might be back with questions during the process. Off to work!
Old Mar 20, 2007 | 09:24 AM
optikal illushun
hows the project coming along?
Old Mar 20, 2007 | 12:13 PM
bc30629's Avatar
bc30629
Going to pick up the parts today. If i can locate them all i'm gonna start on wednesday. I'll keep ya'll updated. Thanks
kydavison
Aug 16, 2020 03:47 AM
speedsauto
Jan 30, 2016 09:49 AM
Front1/4
1947 and Older Ford Trucks
Apr 16, 2013 07:51 AM
jesse1385
Jul 13, 2005 10:40 PM
jules
Dec 27, 2000 09:11 PM
