normal EGTs
Old Mar 14, 2007 | 08:24 PM
  #31
Uzumati's Avatar
Uzumati
Stock housing - 3" sewer coupling, 3" pvc cap, air fitting, gauge. Someone has a pic of it in their galley but I cant remember who. Look at dieselsite's and you'll see how to build it.
Old Mar 14, 2007 | 08:29 PM
  #32
mudracin74's Avatar
mudracin74
then listen for leaks?
Old Mar 14, 2007 | 08:34 PM
  #33
Uzumati's Avatar
Uzumati
pressureize to 20 -30 lbs and watch for pressure drops and listen for leaks
Also a spray bottle of ivory liquid and water can help pinpoint a leak
Old Mar 14, 2007 | 08:39 PM
  #34
mudracin74's Avatar
mudracin74
do i pressurize the intake of the turbo, or after the turbo?????
  #35
Zwalters's Avatar
Zwalters
You can take a very little bit of soap, and mix with water. Fill a little eye drop bottle half full. Shake it and lightly spray the bubbles on your suspected leaks or any area you think could leak. If the bubbles die off fast there is your leak. If you spray just the soapy water without the bubbles, the area should make bubbles. This is a home made version of leak-tec. Maybe it will help isolate your leak.
Old Mar 14, 2007 | 08:43 PM
  #36
Uzumati's Avatar
Uzumati
attach the "rig" to the intake flange on the turbo
Old Mar 14, 2007 | 08:44 PM
  #37
mudracin74's Avatar
mudracin74
okay thanks, ill try that this weekend and see were it gets me
Old Mar 17, 2007 | 01:58 PM
  #38
DP-Tuner's Avatar
DP-Tuner
PREMIUM SPONSOR
Originally Posted by mudracin74
hey everyone, i recently started seeing an increase in my EGTs the past week or so, and dont know if its something to be worried about. as my sig states i have 6637, wicked wheel, and 5" mko. at 70 down the highway i was seeing between 500 and 600. now in the last week i am seeing between 700 and 800 at the same speed. now before the last week it has been colder than a well diggers *** and then it warmed up to the high 60s this week. is the increase in outside temp causing the increase in EGTs or should i start looking for problems. also i used to be able to run the quarter w/o gettin real close to that 1200 mark, now i hit the 1200 mark before i even get to 60 mph. ive havent owned this particular diesel in the summer so i dont know how it runs in anything but cold weather.
Not sure how I missed this. Since this all started after the ww was installed I have to think up pipes near the seals are not fully tightened. It is very important to make sure after taking off your turbo to tighten everything down good. You might think it's tight enough but then sure enough it's not. Double check that. With an increase in boost your are going to see and increase in EGT's, it's normal. When you downshift on the grade you will see higher EGT's because you are asking for more fuel when you hit the throttle to get back the momentum to make it up the hill. Right before the shift,hit the OD button and this will help with your egt's. Thinner air will only make egt's higher not colder air. Did you have the turbo balanced after the WW was put on the turbo? Jody recommends this.
If you have not called Jody, give him a call first of the week to see if he can think of anything else.
Thanks,
Diane
__________________
Jody & Diane Tipton- DP-Tuner®
FTE Legacy Sponsors since 2006
Custom tuning for 7.3l, 6.0l, 6.4l,6.7l, Ecoboost,
Get Tuned! 828-221-0076 ext. 802
Become our Facebook Fan
ImConfused666
20
Jan 31, 2013 04:18 PM
harleyjohn45
80
May 5, 2009 08:24 PM
canuckelhead
23
Apr 19, 2009 09:20 PM
sticks25
41
Jun 23, 2008 01:12 AM
Jerrod
30
Apr 2, 2006 07:15 PM
