crazy question
Old Mar 12, 2007 | 05:15 PM
hiball3985's Avatar
hiball3985
crazy question
I should know this but don't..looking at my collection of cams, not all FE, I started thinking what is the difference between a solid and hydrulic cam???
Old Mar 12, 2007 | 07:30 PM
acheda's Avatar
acheda
Actually, the mechanical cam is more complex than the hydraulic. There are "quieting" ramps before & after the main cam lobe. These ease the valve train through the valve lash & help keep down the noise. The hydraulic lifter allows running at zero lash, so these extra parts of the lobe shape are not necessary.
There may be more differences, so I'll watch this thread & see if I can learn something new.
P.S.: I once owned a '57 panel w/223 & OD. (Oh, I also once owned a '65 F-100 w/390 & 4-spd.) Congratulations on your good taste in trucks!
Old Mar 12, 2007 | 08:04 PM
hiball3985's Avatar
hiball3985
thats along the lines of what I wanted to know, is it just the grind or is there any difference in the material the cam is made of?? I remeber back in the day when some guys in the nieghborhood with 55 Chebbies pulled the hydrulic lifters and put in solids on the same cam...so it made me think what would happen doing this or putting hyd lifers on a solid cam??? anyone ever try this
Old Mar 12, 2007 | 08:14 PM
acheda's Avatar
acheda
Solids on a hydraulic cam would be noisy and would probably beat themselves to death eventually, but the other way around should work. Most of the stock cams and the low-end aftermarket cams are cast iron that are heat-treated on the surface. The cast-iron lifters are similarly hardened and are compatible. More exotic cams are hardened steel and their lifters are different - right now the details elude my memory. Maybe someone else can expand on this.
Old Mar 12, 2007 | 10:01 PM
aMoneypit's Avatar
aMoneypit
Zero lash hydrolic lifters on a solid profile will really scream, won't idle, in fact it'll hardly run under 2K, but the top end is awesome.......Won't work!!!! The ramp to take up the lash will be opening the valve instead of taking up the lash. Way too much overlap/duration.............aMP
Old Mar 13, 2007 | 11:09 AM
hiball3985's Avatar
hiball3985
thanks guys, that satisfies my curiosity
foofees
Nov 6, 2016 09:31 AM
Weberman3
May 28, 2011 10:24 PM
ptboi94
May 19, 2011 09:20 PM
mikehallbackhoe
Jun 5, 2010 09:54 AM
oldblue31
May 21, 2005 08:13 PM
