I hope you took it easy......um 1200* creeps up pretty fast when you have your foot in it. Glad to see you spanked a civic lol.
And your Torqueshift will Not be happy as well. Inline fuel modules (or any of Banks performance modules for the 6.0) do not properly address the transmission. Banks has scattered more than one Torqueshift around here.
Yea, I was scarred of that as well, that is why I opted for the bullet. It is not crazy amounts of power but enough to have fun. IN sport mode it adds 65hp and 100 lbs torque. I have noticed not to "downshift" from sport to stock while rolling under throttle...finger slipped
Just remember in stock tune the factory out put is 325Hp & 560lb/ft at the flywheel, which is 276Hp & 476lb/ft at the rear wheels. The "bullet" is adding 65Hp & 100lb/ft ar the rear wheels. So you have added 24%Hp & 21%lb/ft at the rear wheels with the Banks unit.
The factory Torqueshift strategy has slip in it so that it shifts smoother to keep the soccer moms happy, this leads to excess wear in stock tune. The Banks Bullet is just compounding this problem. Watch your transmission closely for excess wear.
Thanks for the advise, I did not realize that it was putting that much more power to the torque converter/flywheel. Always glad to get good advice from you guys.
Use a smart & disciplined right foot. Do not hook up to a large load and see how fast you can climb the hill. The extra power has to go somewhere and it will start finding the weak links in the chain.
