Windshield Washer Bag
Old Mar 10, 2007 | 09:53 PM
cbfomoco's Avatar
cbfomoco
My 66 orginally had windshield washers. the pump is there and works, and the braket, and the squirters. I know that it takes a bag type resevor. Can anyone tell me what bag to look for? are they all the same as in size and mounting points? What color was the bag orginally. I am wanting to get the system working and was wondering what to look for. Thanks
Old Mar 10, 2007 | 10:05 PM
airharley's Avatar
airharley
The bags look like this one. I am not too sure if they are all the same or not but this will give you an idea.
http://www.americanpony.com/store.mv?p=592080
Old Mar 11, 2007 | 07:51 AM
carras's Avatar
carras
I have a red one in my 66, but can't say whether it's original
Old Mar 11, 2007 | 08:01 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C1AZ-17618-D Washer Bag with Integral Cap-RED "See Clear" (cap was hinged, not removal like the one pictured in the link above).
This is the bag that was installed at the factory, but there were several different dealer installed kits available, and all will work. For example, one from a 63/64 Galaxie with the long BLUE bag will work on a 61/66 pickup. So, it's impossible to say which bag is correct.
Whatever bag you need will depend on the length of the bracket. Since both factory and dealer installed kits were used, there are different sized brackets. So the long blue Galaxie style bag won't attach to the shorter Mustang/Falcon/Fairlane bracket..unless one of those kits was dealer installed on a pickup.
Old Mar 11, 2007 | 08:30 AM
Tedster9's Avatar
Tedster9
Woah - a windshield "washer-pump" - sounds pretty fancy! That means I wouldn't hafta git outta th' truck t' warsh down the glass. What will they think of next.
Old Mar 11, 2007 | 01:47 PM
NumberDummy
C1AZ-17664-C Washer Pump (fits all late 50's thru 1964 cars & up thru 1967 on trucks.
For slot cars fans, those washer motors can make for a pretty fast 1/24th scale model.
The dealer installed washer kits also can be hooked up to act as sprayers, by routing the washer tees to spray the radiator cores.
Yeah, you can use Rain X to help clear the glass, but cut plug chewing tobacco works pretty good too. In the old days when cars didn't have windshield wipers, it was used with succcess, and still does a fair job today..
Old Mar 11, 2007 | 02:05 PM
Mil1ion's Avatar
Mil1ion
NPD has them.
I saw them on their web site yesterday.
Old Mar 11, 2007 | 07:35 PM
desertwest's Avatar
desertwest
Here's one on my old 64 parts truck...
Here's one from my old 64 f-100 parts truck...
Well, nevermind, I have a 143kb jpeg but the system keeps saying "invalid file type"... won't let me upload it.
Anyway, mine is red and says "FoMoCo Genuine Accessories" on it.
Old Mar 12, 2007 | 10:52 AM
Customcab's Avatar
Customcab
I could be wrong; won't be the first or the last time either. But wasn't the 64 models below OEM to have a red washer reservior bag, and 65 up to early 70's to have a blue bag. I personnelly replace my old blue bag on my 65 with a 66 mustang black reservoir bag; like the one airharley posted. Check my gallery to see. I use the same OEM bracket from my blue washer bag and attached the 66 mustang version with not problem.
Just didn't know it was a dealer option to select colors; I just always though each color dispay an era of models.
Mitch
Old Mar 12, 2007 | 11:20 PM
NumberDummy
Just didn't know it was a dealer option to select colors; I just always though each color dispay an era of models.Mitch
Mitch, dealers installed anything that would work, and there's at least six red bags, and four blue ones. There's at least three brackets.
Mustangs are different and never used the same blue bag the trucks did. The blue bag used on the F Series trucks (from the 63/64 Galaxie kit) was 10 or so inches long, with 5 inch wide white letters that said FoMoCo. The dealer installed kits made for the trucks used a red bag, but because most of the car washer kits would work, you'll see just about anything. Mustangs used the shorty black bag, except = Mustangs made before 8/23/64 had red bags. There wasnt' enough inner fender apron space for the larger bags.
Regardless of whether it's a truck or a Fairlane, what ever washer kit was handy was used. Windshield washers didn't become standard equipment till January 1, 1966.
Old Mar 13, 2007 | 11:54 AM
Flyn66dtmn's Avatar
Flyn66dtmn
FWIW- i installed the washer tank from the 76 donor i used and it fit perfectly. ( contour was the same as the fender well). also i had to put a filter between the tank and the nossels as i couldn't seem to get the tank clean enough to stop plugging up the nossels. doesn't take much to plug them. Dutch
Old Mar 13, 2007 | 12:04 PM
customcab66's Avatar
customcab66
I have the original in my 66 custom cab and it is blue
upnorthman
Aug 10, 2015 08:28 AM
edo488
Feb 9, 2014 03:15 PM
johnmel59
Nov 18, 2013 05:02 PM
Curt Lefferts
15
Jan 30, 2004 09:57 AM
