Finally got in my new glow plug relay, also my coolent tank. Put the battteries in and of course there was not enough juice to turn the motor over so I went ahead and jump started it. Started up with no problems. When I went to turn it off the ABS light was on. So I went ahead and disconnected the battteries of 30 seconds and tried it again and the light was on. I have no scanner to check and didn't know if this has happened to anyone.
My bad i was thinking air bag. Go for a drive it should go off once the ABS system has enuff data.
A self-test of the solenoid valve coils and the pump motor is performed when the vehicle is started. During starting, the brake pedal must be released to run the self-test. If the brake pedal is depressed or a failed brake switch occurs, the self-test is run at 6 km/h (4 mph) regardless of brake pedal position.
