Help!!
Old Aug 5, 2012 | 02:48 PM
76xltcc's Avatar
76xltcc
Help!!
Project: Swap 1997 7.3 powerstorke into my 76 xlt crew cab.
Problem: Started removing wiring (that I thought I wasn't going to need) from donor 97 F350. I removed only headlight, turn and parkin lights from the front and horn.
Before removing wireing the donor truck started up fine. I don't think that the wire removal has anything to do with why the truck will not start.
I tried starting the truck with the main batttery (which was very low on juice) tried to crank but couldn't. Installed auxilairy battery and truck cranked fine but would not start.
What logical diagnostic procedures can I follow to deternmine where the failure is? (pump, harness,???)
Thanks,
Hector
Old Aug 5, 2012 | 03:21 PM
96ford250's Avatar
96ford250
Was there any smoke coming out of the tailpipe
Old Aug 5, 2012 | 03:35 PM
fordpride's Avatar
fordpride
That wiring has a lot do with it. You have missing grounds now.
Old Aug 5, 2012 | 05:06 PM
96ford250's Avatar
96ford250
Yea but if there's smoke there is fuel weather it's rich or lean is another story
Old Aug 5, 2012 | 05:44 PM
Ken_C's Avatar
Ken_C
Some wiring diagrams from 97 may be helpfull. these were a sticky at the top of the main page but someone thought it was a good idea to totally bury them so... https://www.ford-trucks.com/forums/1...l#post11383134 the diagrams give the actual locations on the chassis where things are grounded.
Old Aug 5, 2012 | 06:24 PM
fordpride's Avatar
fordpride
I had those grounds by the driver side battery dissconected cleaning them and it started raining so I went to start my truck to move it in the garage and it was a no go would not start
Old Aug 5, 2012 | 10:13 PM
76xltcc's Avatar
76xltcc
Help!
I wasn't looking for smoke so I did no notice. I'll try cranking it tomorow to check for smoke.
Old Aug 6, 2012 | 05:45 AM
Jeff396's Avatar
Jeff396
I've had several occasions where my truck seems to turn over fine but just will not start. In every case I put a charger on the truck for a while and then it started up fine. Unlike any gas vehicle I've ever owned these trucks really need the batteries to be in a good state of charge to get the motor to fire but they're still good enough to turn it over.
Jeff
Old Aug 6, 2012 | 08:14 AM
madpogue's Avatar
madpogue
The usual checklist:
* WTS light?
* Does the tach move?
* (already asked) any white smoke?
Old Aug 8, 2012 | 11:16 PM
76xltcc's Avatar
76xltcc
Happy days are here again!
Jeff
I charged both batteries and my donor truck started right up!
Thanks everyone for the input, it's greatly appreciated!
Hector
76xltcc
GOODOLEF250
17
Jun 22, 2019 04:52 PM
onefarmer
104
Mar 13, 2015 05:22 PM
JRB65
17
Feb 7, 2013 07:56 AM
WACountryBoy89
13
Nov 17, 2012 04:39 PM
BLACK F 350
13
Dec 31, 2010 05:04 PM
