Neutral Safety Switch
Old Mar 9, 2007 | 02:46 PM
The67Beast's Avatar
The67Beast
Hi Guys,
I have a 1984 F-150 Manual Transmission (top-loader) installed in my 67 4X4 Pickup. This is the one with the granny low first gear. I have two questions for you...
(1) Where is the Neutral Safety switch located? and (2) where is the backup/reverse light switch located? There is some sort of switch located on the left side of the transmission, but I want to know what it is before I just go hooking up wires.
Thanks.
Old Mar 9, 2007 | 03:13 PM
Mil1ion's Avatar
Mil1ion
On the 84 is should be on the column where the ignition switch rod links to.
or at the back of the transmission.
see bottom illustration.
https://www.ford-trucks.com/user_gal...&photoid=93334
Old Mar 9, 2007 | 03:31 PM
The67Beast's Avatar
The67Beast
If the switch is on the column of the 84, wouldn't there still have to be a connection made somewhere on the transmission itself. As best as I can tell I only have one place to make a connection on this transmission. Could that connection serve as both the Backup lights and the neutral safety switch at the same time??
Old Mar 9, 2007 | 04:43 PM
mudgepondexpress's Avatar
mudgepondexpress
Neutral safety switch on the early 80's F series was a positive stop built into the column. There was no electronic / interupt switch. Put the tranny in gear and try to turn the switch...won't go will it? Mechanical stop.
This might not be a case for all of them, but the early 80's I have dealt with are this way. When converting mine to the GT SEFI 5.0, I had to get a neutral/reverese switch off a later model to retrofit my early AOD.
Kenny
Old Mar 9, 2007 | 04:49 PM
mudgepondexpress
Sorry...I didn't read manual tranny. I didn't know the manuals had neutral stafety switches on the pickup. Are you sure you don't have a clutch switch instead?
Kenny
Old Mar 9, 2007 | 05:02 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C9TZ-15520-C .. Switch, Backup Lamps~Screws into Shift Tower.
Fits all 1980/89 F100/350 & U150 with Warner or New Process 4 Speed trans.
Also fits 1967/79 F100/350 with 4 speed manual transmissions (as above).
No neutral switch used on this application
Old Mar 10, 2007 | 05:05 AM
The67Beast's Avatar
The67Beast
Thank for all the info. To my knowledge there is no type of "clutch switch", It may not have a Neutral Safety Switch, but I don't know so that's why I was asking.
Thanks again.
Old Mar 10, 2007 | 01:23 PM
Mil1ion's Avatar
Mil1ion
see this page and click the Figure that applies to your trans to see B/U light switch.
http://www.autozone.com/servlet/UiBr...3d800a8d18.jsp
Furr308
1978 - 1996 Big Bronco
Mar 2, 2015 04:25 PM
spaytons
May 7, 2014 07:33 AM
oldgrezmonke
22
Oct 15, 2013 03:22 AM
samahi72
Sep 8, 2013 08:44 AM
mauicruza
May 1, 2006 09:28 AM
