87 F-350 Where is the neutral safety switch?
My father in laws truck will not turn over unless I jump the starter selenoid. I pulled off the two wires going to it and neither of them are hot. So working backwards, I figure it has to be either the switch or the neutral safety switch.
I thought I would start with the neutral safety switch, but I don't know where it is located on this truck and what is the easiest and best way to access it.
Of course if you have any other suggestions as to why he is not getting power to the selenoid, I am listening.
Thank you
Thank you
Received 3,090 Likes
on
on
Just looking at another post with ignition problems. Here is a post I used to fix the actuator on my 1986
1983 Ford Bronco Diagrams picture | SuperMotors.net
Gives a good description of how to get the column apart to get to the actuator.
2002exPSD
03-06-2011 10:53 PM
