alcohol carb??
Old Mar 14, 2007 | 11:48 AM
dinosaurfan's Avatar
dinosaurfan
Smile alcohol burning
Bear, just beacause we CAN run 50 or 60* of lead doesn't mean we should. I have to wonder if the guys running that much advance keep getting faster as they advance the timing, usually there comes a point of diminishing returns. If you keep advancing, the fuel burns too soon, and the piston actually has to compress the already burning mixture. But the alcohols have so much detonation resistance that you can get away with quite abit. I would suspect that the guys who run 50 or 60* of lead are suffering from ignition lag. By which I mean that there is longer period of time from when the spark arrives to when the fuel actually starts to burn. The alchohols both have a wider flammability spread and faster flame speed than gasoline, but they seem to need greater amperage at the plugs to get the fire lit. What type of ignitions are these guys running ? My guess would be that if they switched to an 8 amp system with copper wires and tried about .080 plug gaps, they wouldn't need so much lead. Duraspark, HEI and Chrysler's breakerless all put out about 4 amps, points run about 2.5. DinosaurFan, at work but on lunch
Old Mar 14, 2007 | 11:58 AM
hoxiii's Avatar
hoxiii
Alcohol needs more juice to fire and bigger gaps becuase it runs at a much richer mix than gas and is more difficult to vaporize, so there are more and larger fuel particles to ignite.
And you definitley can start to lose power from over advanced ignition before you start to knock, so I too wonder if they run that much becasue they can or becasue they should,
Justin
RustyTrustyF150
31
Jan 7, 2008 09:55 AM
staysbroken
Alternative Fuels, Hybrids & Mileage
17
Sep 10, 2007 08:06 PM
uuranium
May 10, 2006 06:09 PM
dinosaurfan
48
May 13, 2005 08:56 PM
tess100
Mar 18, 2004 10:43 AM
