alcohol engine build
Old May 1, 2006 | 11:43 PM
uuranium's Avatar
uuranium
i am interested in building an engine to run on alcohol but have no clue on what needs to be done to allow this. if anyone has any reading on the subject or has built up a alcohol engine i would really appreciate the help.
Old May 2, 2006 | 09:34 AM
tomw's Avatar
tomw
Thinking out loud, are you talking of a drag engine, they run on methanol? Or for road use? The former may have info on how to do the latter. Most problems are related to the fuel corroding the components and mixture. You have to re-figure the fuel mix ratio and fiddle with a carb or fuel injector, but your octane is a lot higher. The injectors are different for alcohol fueled engines. Carbs would need different sized jets and/or metering rods
You could take an E85 engine control system from a Ranger or Taurus Flex-Fuel dealy, and refit that. GM has some also, but I am ignorant. Where are you gonna get your fuel? Road tax (heh) must be paid. Uncle Sam wants his.
tom
Old May 2, 2006 | 11:43 AM
rusty70f100's Avatar
rusty70f100
Yeah, I guess we need some info about what alcohol you're talking about. Here's some choices:
1. Methanol. Low BTU's, low stoichiometric ratio of about 5:1 to 6:1. Expensive. Very high octane. I think it's up around 120.
2. Ethanol. Higher BTU's than methanol, but lower than gasoline. Stoichiometric ratio is about 9:1. Less expensive than methanol. Octane, IIRC, is up around 110.
3. E85. 85% ethanol, 15% gasoline. Readily available at gas stations in the midwest and some other areas. Priced less than regular gasoline. Octane rating is 105. This is the one I'd pick...
You can build a very high compression ratio engine without having to resort to a huge cam with ethanol. The key term here is dynamic compression, or the amount of compression the engine actually builds, when you figure in cam timing. You can build and engine with a lot higher dynamic compression for alcohol due to it's high octane rating. Here's a chart:
http://popularhotrodding.com/tech/03...press_07_z.jpg
And here's a calculator that will figure up your dynamic compression ratio:
http://www.kb-silvolite.com/calc.php?action=comp
Old May 2, 2006 | 11:45 AM
uuranium's Avatar
uuranium
i was actually going to make my own fuel. evidently there is a book on it and i figured it would be pretty fun. this is going to be a dragster with twin t76's and 355ci. i am trying to gauge the cost of the conversion and you brought up something that i had not thought about, ohol specific injectors. i will be running a mega squirt so tunning won't be too much of a problem. thanks for the help.
Old May 2, 2006 | 11:48 AM
uuranium's Avatar
uuranium
thanks for the sites and the info on the fuels, i will end up running ethanol if i do the swap, any ideas on cold starting?
Old May 2, 2006 | 02:25 PM
Torque1st's Avatar
Torque1st
Posting Legend
Cold startup is why they run 15% gasoline in E85. It might be just as good to run E85.
Old May 2, 2006 | 07:26 PM
uuranium's Avatar
uuranium
i have been thinking about running race e85, 85% ethanol and 15% race gas but don't know if anyone makes that, so i would most likely have to make my own.
Old May 2, 2006 | 11:40 PM
Torque1st's Avatar
Torque1st
Posting Legend
Lots of guys run E85 for race gas.
Old May 7, 2006 | 10:50 AM
captchas's Avatar
captchas
Guest
can't help you with eth, as most of us running alcie classes use meth, base build up is the same as top fuel just the motor last a lot longer. cold start we always give it straight gas into the blower intake to start it.
one thing for sure before you waste money get a rule book and be sure you can do as you want to. and good place to get up to date info is at a round and round short dirt track as those guys are running alcie all the time
Old May 7, 2006 | 10:01 PM
Torque1st's Avatar
Torque1st
Posting Legend
I have heard that more sanctioning bodies are allowing E85 all the time as a substitute for leaded race gas.
Old May 9, 2006 | 11:00 PM
uuranium's Avatar
uuranium
i'm not building it for a class, more or less as an expirement so that i can learn to make ethanol and tune usnig a stand alone system. haven't really been able to think about it much since finals were this week. thanks for the responses and ideas.
Old May 10, 2006 | 12:27 AM
Torque1st's Avatar
Torque1st
Posting Legend
Check here:
http://www.answers.com/topic/e85
There are additional considerations if you make your own Ethanol.
Old May 10, 2006 | 06:09 PM
Green Streak's Avatar
Green Streak
If the octane is that high maybe I should keep my D2VE heads. Never had the heart to throw them away.
beartracks
New Mexico Chapter
Mar 13, 2017 12:49 AM
scottperkins
1997 - 2003 F150
Jun 29, 2016 10:33 PM
351Cleveland C4
Alternative Fuels, Hybrids & Mileage
Sep 29, 2013 04:58 PM
dchamberlain
Mar 21, 2011 03:07 PM
staysbroken
17
Sep 10, 2007 08:06 PM
