1978 - 1996 Big Bronco
bronco vs. F250
Old Jul 11, 2002 | 09:09 PM
malek31337's Avatar
malek31337
bronco vs. F250
i need help. i have a 97 F250 and am looking at replacing it with a 96 bronco. the problem is, i can't really decide what would better suit my needs. my needs being mainly off roading. and i don't know about the reliability of the bronco. any help is appreciated. thanx
Old Jul 12, 2002 | 02:03 AM
whitebenz's Avatar
whitebenz
bronco vs. F250
I have 324000 on my 85 Bronco and can only say great things about her. You will find that the Bronco will out turn the P-up with no problem making it a better choice in tight Quarters.
dj
Old Aug 1, 2002 | 12:08 PM
flyn_ace_99's Avatar
flyn_ace_99
bronco vs. F250
I am in an off road club at my school and I own a Bronco myself. If you want the truck for off roading, the bronco will be your best bet. That way you don't high center it in tough spots. ;-)
Old Aug 1, 2002 | 01:48 PM
Steve_Uzi's Avatar
Steve_Uzi
bronco vs. F250
Broncos have a Great turning radius, shorter wheel base.. are cooler to drive than a Pickup... but.. 1/2 ton rating.. good enough for 35's and some good fun...
VOTE -----> Bronco
Old Aug 1, 2002 | 02:26 PM
fast_eddy's Avatar
fast_eddy
bronco vs. F250
The Bronco rocks for going off-road, but the F-250 is going to have some stronger drive train/suspension components. The Bronco is pretty beefy for a half ton, though!
Old Aug 2, 2002 | 09:15 PM
Pentekno2's Avatar
Pentekno2
bronco vs. F250
Well, it depends on what type of off-roading you are talking about. If you just want to "off-road", or Play around in the mud, either one will work great, bronco or F-250. If you want to do some real offroading, like Trail blazing, or light crawling, anything of that sort, your best bet is the bronco for the shorter wheel base, lighter weight and better turning radius. Like they said above, with that long wheelbase of the F-250, your chances of high centering greatly increase, it weighs a bit more than the Bronco as well, and also It cannot turn the tight turns that the Bronco can, which in offroading can make the difference between making a turn, or rolling your rig right off the trail. So those are my two cents.
Hope this helps
Daniel
Old Aug 2, 2002 | 10:28 PM
brokebronco's Avatar
brokebronco
bronco vs. F250
As I own a Bronco and an F250 I can tell you for manuverability(sp) the Bronco will drive better off road due to the 104" wheelbase and the lighter and better balanced chassis(sp). However I would not trade the strength of my 250. I have broken many 9" rearends so I had to put a 10.25 in the bronco. Sometimes the added length of the 133" wheelbase can help on obstacles. as some folks on this site will say my 2cents.
BROKEBRONCO
Old Aug 4, 2002 | 04:08 PM
luvmybronco's Avatar
luvmybronco
bronco vs. F250
I've owned several Ford p-ups and broncos, from '73 to '88, and I wouldn't trade my bronco for anything. I offroad with a buddy who has an f-250 that's built, and it's great offroad. The advantage I have with my bronco, ('78, 6" lift, 33's, 360cid w/4bbl), is that I can turn around on almost any trail, and he has to back out. The tight turning radius is very important for serious wheelin'.
Mark
If it ain't broke, your not trying hard enough...
Old Aug 16, 2002 | 03:05 PM
brokebronco
bronco vs. F250
As a side note, I just bought another 84 Bronco with the 6 and also have a rusted out 82 that I use for parts.
BROKEBRONCO
84 Bronco 351HO/C-6/208/10.25 Rear/D44TTB Soon to have D60 Front/NP435
86 F250 351HO/C6/10.25 Soon to have a front axle and the ZF tranny
Old Aug 16, 2002 | 06:48 PM
billyb's Avatar
billyb
bronco vs. F250
Jetmech6
Oct 26, 2014 04:13 PM
Blown 331
Feb 8, 2013 08:14 AM
Krisx125
Dec 8, 2010 02:26 PM
92BRONCO92
Jul 23, 2010 09:17 PM
pdrhodes1
1966 - 1977 Early Broncos
Nov 11, 2006 12:42 AM
