front springs
Old Mar 8, 2007 | 03:33 PM
matt0963's Avatar
matt0963
Glad I can help. I've learned alot from this forum and it only right to give some back.
Old Mar 12, 2007 | 07:45 PM
428fourby's Avatar
428fourby
I installed the new springs and shocks on the weekend and ended up with a lift of 3/4".
I thought it was going to be a little more b/c the free length difference was about 2", oh well, it looks better than it did!
Old Mar 28, 2007 | 04:32 PM
TractorGang's Avatar
TractorGang
do they make the adjusyable ball joints for 97 f250 hd. i have pos camber after leveling kit install. i was wondering if the leaf springs would settle a little after time? how much to have that job done and alligned, thanks..
Old Oct 29, 2007 | 07:59 AM
wimpster's Avatar
wimpster
i would like a 2" lift 92 2x4
so.. have you found anything that would have given you a 2" lift? or can you suggest anything to try. i would like to level out my 2x4 92
Old Oct 29, 2007 | 06:51 PM
428fourby's Avatar
428fourby
You could buy a spring for a 2" lift, or maybe a 4wd spring will give you what your looking for.
Old Oct 29, 2007 | 07:00 PM
andym's Avatar
andym
4wd springs are exactly the same as 2wd springs.
To lift it 2", you need a leveling kit. It raises the front of the truck by about 1.5" to 2". You will also need a caster/camber sleeve that is designed to work with a small lift such as this. Unfortunately, this requires disassembly of much of the front end to install, and an alignment shop that knows how to deal with lifted trucks. Your local alignment shop may not have a clue about any of this and will more likely than not give you wrong or misleading information.
shawn11762010
May 13, 2011 08:07 PM
CougarXR02
Feb 26, 2011 01:44 PM
Neal 97 250
Dec 5, 2009 11:50 PM
bloodhound51
Offroad & 4x4
Jun 25, 2006 10:15 PM
Superdave
18
Dec 11, 1999 10:34 PM
