Spring codes????
Old Feb 26, 2011 | 01:14 AM
CougarXR02's Avatar
CougarXR02
Spring codes????
Since there is an entire alphabet's worth of different front coil springs, where do I need to look to find the Spring Code on my 1993 E-150?
That being said, any chance I can fit 250 or even 350 springs up front?
Old Feb 26, 2011 | 05:27 AM
JWA's Avatar
JWA
On the left door jamb there should be a Vehicle Certification sticker which has a lot of information about your entire van. Specificially at the bottom there is a line of code numbers/letters looking like this:
Under #12 or where it lists SPR you might find some useful information. I will add I've been trying to determine which front coils I have but most local spring shops say they need to measure the wire diameter, diameter and height of the spring installed before determinine anything. I'm guessing once they know what I have they could change to suit me.
Hope this helps even a bit!
Old Feb 26, 2011 | 01:44 PM
CougarXR02's Avatar
CougarXR02
Totally helps, thank you! I'm just thinking while I'm in there to find some newer, low mileage springs. So I go to scan Car-part.com and there's literally 20 or more spring letter codes. Makes you wonder why. On the plus side it seems as though the 3/4 and 1 ton coils were just a different letter code.
Xcursion88
Jun 6, 2014 11:47 AM
Studawg
Feb 16, 2011 07:02 PM
propane one
Apr 4, 2010 07:06 PM
broncorif
Mar 23, 2010 06:20 PM
