1978 - 1996 Big Bronco
Turning radius
Old Aug 16, 2002 | 04:02 AM
scionti 94's Avatar
scionti 94
Turning radius
Are there any adjustments possible to reduce turning radius? I need the complete two lanes when making a U-turn, hoping there is not a curb on the outside lane. I have been told by a some guys that there Bronco's can turn on a dime. (Matter of speech)
'94 EB,5.8,towing package, Rancho RSX7000 shocks,Westin nerf bar, Energy Suspension poly, keeping it basically stock
Old Aug 17, 2002 | 05:59 AM
8996EBBroncos's Avatar
8996EBBroncos
Turning radius
All I can tell you is that my 89 turns alot tighter than my 96. Considering your 94 is the same configuration as my 96, I doubt you'll get a whole lot more turning out of it. But their maybe an adjustment. I psoted back so that it would 'bump' this thread to the top. Maybe someone else can tell you, Honny?
Old Aug 17, 2002 | 08:32 AM
scionti 94's Avatar
scionti 94
Turning radius
8996,
Appreciate the reply and the "bump" up. Without any responses, they can drop fast. Plan on taking it into a shop, but wanted some info before going there. Again, thanks.
Old Aug 18, 2002 | 03:08 AM
whitebenz's Avatar
whitebenz
Post Turning radius
My 85 can turn sharper than a yugo (no kidding I have done it).
dj
Old Aug 19, 2002 | 11:20 AM
embury4's Avatar
embury4
Turning radius
Do you have manual hubs or auto? From what I understand, with manual hubs you will have a much better turning radius. If you've got the auto hubs, then you're probably SOL unless you swap them...
Jeff
'88 EB Bronco 5.0L
Old Aug 21, 2002 | 07:28 PM
mcard's Avatar
mcard
Turning radius
I don't know about any adjustments but my 82 turns in a much smaller radius than my wifes 99 blazer 4x4. For a little vehicle it takes a lot of room to turn it around. - Mike
Old Aug 21, 2002 | 08:11 PM
8996EBBroncos
Turning radius
Other than a vette or camero, I've NEVER seen a Ch@y that turned worth a *****!
Old Aug 21, 2002 | 10:38 PM
fordnut74's Avatar
fordnut74
Turning radius
My 92 EB turns tighter than my 96 camry, and will there is no comparison to my 351capri. I believe they all have basically the same front end. on mine there are adjustable bumpstops located behind each front tire that the knuckle contacts when turned to the locks. there will be one on both sides, and a simple wrench should do the trick. I have not actually adjusted mine, but did notice them while scoping out the undercarriage. let us know if it works for you.
Old Aug 21, 2002 | 10:42 PM
BroncoScott's Avatar
BroncoScott
Turning radius
My '89 turns so well I am amaze every time in a parking lot manuver. If you can't go around it, run it over, your in a Bronco, FULL SIZE.
Old Aug 22, 2002 | 12:05 AM
tothfngclw's Avatar
tothfngclw
Turning radius
My 91 turns on a dime also. I drive an extended Ford Natural Gas E350 van for a service vehicle at work and it takes 2 blocks to turn around LOL. I don't really see how manual hubs or auto hubs would make a difference. I am by no means an expert but I can't see it affecting the steering. I do know that your turning radius is reduced in 4X4.
Old Aug 22, 2002 | 04:21 PM
TheGreep's Avatar
TheGreep
Turning radius
My '92 turns tight even with the big fat tires I have rubbing at full tilt, And the suspention should be the same from '92 to '96.
1992 Bronco Eddie Bauer: K&N, Magnaflow Exhaust, too much money in stereo equipment, 33X12.50 tires on stock suspension. Check it out: [link:aries.ccicom.com/truck|My Fat Truck]
yosemite's Avatar
yosemite
Turning radius
94xlt150
Mar 9, 2015 06:51 PM
Randall1984
Mar 15, 2014 06:20 PM
azfarrier
6.7L Power Stroke Diesel
Dec 12, 2010 11:16 PM
HiDesertRat
106
Jul 4, 2005 11:26 PM
ckrichard
General Automotive Discussion
Jan 25, 2005 11:46 PM
