Tkx for help with problem, now new problem
Old Mar 3, 2007 | 04:13 PM
the_sharkster's Avatar
the_sharkster
Red face Tkx for help with problem, now new problem
Thanks for all the info on getting my 1989 F-150 up and running after being transported. Now that I can start and be running, it is acting like it is loading up. I can hold the throttle down about half, and she runs fine. Go to idle, she shakes and loads up, then stalls. The previous owner had already installed a new idle air control valve. Could it be the computer? Just guessing.....
Any help at all will again be greatly appreciated !!
Old Mar 3, 2007 | 05:38 PM
mhg's Avatar
mhg
start by checking for vacuum leaks
the EGR is notorius for this
also check the fuel pressure regulator
Old Mar 3, 2007 | 05:55 PM
the_sharkster
I unplugged the electrical connection on the egr and started her up. She ran great. Of course the check engine light came on, no surprise there. Plugged it back in, and back to square 1. Is there any way to clean the egr up? I assume it has carbon in it. Its gotta be expensive to replace it.
Old Mar 3, 2007 | 09:21 PM
nighthawk285's Avatar
nighthawk285
you can take it off and soak it in some carb cleaner, that'll take off the carbon, just do a good job and you're all set....and it might not be as expensive as you think, you just gotta have the OEM number to get a replacement, or at least a price.
Old Mar 4, 2007 | 07:23 AM
subford's Avatar
subford
I wonder if unpluging it would put the EEC computer into limp mode?
should not effect the running of the engine, it just reports back to the EEC computer how far open the EGR valve is. This sensor may have a short to ground and drop the 5-Volt reference voltage down that would change the running of the engine.
The EGR valve does not get a signal from the EEC computer to open at all until you have a warm engine and the throttle is in mid range.
I would check the wiring and connector plugs very close to see if they are bad.
EDIT:
I wonder if unplugging the electrical connection on the EGR would put the EEC computer into limp mode?
Did you get black smoke from the exhaust while it was unplugged?
Old Mar 4, 2007 | 09:55 AM
lv2race's Avatar
lv2race
You may have a bad EVP Sensor, but your symptom sounds like a MAP Sensor. First thing you want to do is check for codes. Many parts houses will do this for free, you can get a code reader, or you can do it yourself. Check the links for more info.
http://fordfuelinjection.com/?p=13
http://www.thorssell.net/hbook/eectest.html
Old Mar 4, 2007 | 10:32 AM
subford's Avatar
subford
My post above did not look like that in the editor, it should have looked like this.
Unplugging the electrical connection on the EGR should not effect the running of the engine, it just reports back to the EEC computer how far open the EGR valve is. This sensor may have a short to ground and drop the 5-Volt reference voltage down that would change the running of the engine.
Old Mar 4, 2007 | 01:09 PM
the_sharkster
No black smoke was noticable. I took nighthawk's advice and cleaned the egr with carb cleaner. I first removed the plastic plunger on top, then soaked it. Worked the plunger while it was soaking. I dried it out, replaced the plastic. Started and ran great. She idled well for the first time.
A big shout out to all that helped me. Much appreciated. You guys really know what you are talking about !!!!
Thanks again. If I have any more questions, I will not hesitate to come back !!
davbeisner
Apr 19, 2014 10:56 AM
jayc3169
Jan 26, 2011 08:37 PM
ibleedfordblue
Modular V10 (6.8l)
29
Apr 5, 2007 02:55 PM
Owl
Dec 12, 2005 10:29 PM
