overheating?!?!?
Old Jul 3, 2007 | 09:31 PM
  #31
73f100shortbed's Avatar
73f100shortbed
Ton of bubbles coming out as in air trapped in system or was it foamy?
Old Jul 4, 2007 | 12:17 PM
  #32
bmf2030's Avatar
bmf2030
very foamy. and when ever it was idling the rad fluid didnt seem to be moving around but when i would give it gas it would move around a bit.
Old Jul 4, 2007 | 12:42 PM
  #33
73f100shortbed
If thermostat was open you should see it move around at idle
Old Jul 4, 2007 | 01:01 PM
  #34
Mil1ion's Avatar
Mil1ion
If it was a head gasket the coolant in the rad would bubble like hot tub with the jets on.
Old Jul 5, 2007 | 11:17 AM
  #35
bmf2030's Avatar
bmf2030
after about 5 min thats whats it started to to. but whenever i would floor it it wouldnt bubble... it would stop for a couple seconds
Old Jul 12, 2007 | 02:13 PM
  #36
sum_weirdo's Avatar
sum_weirdo
You know if there's a leak in the gasket the coolant has to go somewhere. Either into the oil or into the cylinders. Either should be detectable.
Old Jul 12, 2007 | 03:49 PM
  #37
boggerted's Avatar
boggerted
I think theres something else amiss with the cooling system and not a head/gasket problem as you seem to think. I would suggest you try these tests and suggestions before you spend all that time and effort on heads:
1. Remove both hoses from the radiator, drain the coolant, and run water through the radiator from the top and let it flush out the rad. Give it some time and try to move the hose around a bit as to clean as many of the louvers as possible on the inside. Once the water comes out clean, you can stop this.
2. Reconnect the hoses and replace them if not already done so. Fill the system with STRAIGHT WATER, dont worry its summer it aint gonna freeze, and you can change it out later.
3. start the truck up and leave the cap off. If your tstat is working, once it opens, it will suck almost all the water you just put into the rad out, so keep on adding water. Once it stops taking on water, stop adding water.
4. If this solved the problem, you can flush out the engine to some degree by opening up the petcock on the bottom of the rad. Keep adding water as it is drained out of the radiator with the truck running. Once it stops coming out dirty, close er up.
ALSO, the plus to using straight water is that if you want to see if you are leaking into the oil, just openm the drain plug on the pan when the engine is cold (preferable overnight). Since the water will settle to the bottom, youll know if you got a inbternal engine problem.
Im just trying to provide all my advice in an effort to save you time. I hope it helps.
Kanfordman
Oct 14, 2021 03:14 PM
Kregj
Jun 6, 2014 05:37 AM
jdcpjc
Jul 7, 2012 03:32 PM
Hmann
Sep 29, 2009 08:06 PM
bkeese
Sep 5, 2006 10:34 AM
