2002 Explorer
Old Jul 7, 2012 | 02:10 PM
jdcpjc's Avatar
jdcpjc
2002 Explorer
Problems overheating. Have replaced thermostat and the housing for it...fan clutch and water pump. Its still overheating especially going uphill when RPM's are higher. How can I check to see if there is a radiator blockage?
Thanks
Old Jul 7, 2012 | 03:32 PM
Ridenred333's Avatar
Ridenred333
Have you flushed the system. You can put some coolant flush in the system follow directions on the bottle and then when you drain it see if a bunch of crap comes out. Also once the engine warms up check the top radiator hose if it a squeese and see if there is pressure in there and if you hear fluid surge thru it. You may have to either replace or take it to a radiator shop and have it rodded and cleaned out.
Rosecity4
Feb 5, 2013 10:36 PM
calfed
Sep 17, 2006 12:30 AM
allanhilliard
22
Nov 25, 2003 09:33 AM
dmarple
Nov 25, 2003 06:05 AM
Dutch123
1978 - 1996 Big Bronco
22
May 31, 2003 12:40 PM
