Sponsored by: Real Truck
Left Side Lean
Old Feb 28, 2007 | 06:53 PM
texex's Avatar
texex
Question Left Side Lean
Upon preparing to install a leveling kit, I measured the front end to see how much lift I would actually end up with ...
Well, what I foud is that the drivers side is 3/4" lower.
Is there something I can do to correct this while I am under the beast?
Thanks
Old Feb 28, 2007 | 07:07 PM
cattlerancher's Avatar
cattlerancher
Ive got the same damn problem, im thinkin about getting all new springs, but that just makes me wonder how long the new springs will last before the sag.
Old Feb 28, 2007 | 07:12 PM
texex's Avatar
texex
Cattlerancher
what year is your rig? How many miles?
I have 89k
Old Feb 28, 2007 | 07:20 PM
cattlerancher
Ive got a 99 f250 with 110,000 on the od. Im thinking about switching the driver and passenger spring just so it will level out. I dont know about you but I dont like the feeling of sitting on a slant while going down the road.
Old Feb 28, 2007 | 08:17 PM
bigtorque's Avatar
bigtorque
does the rear lean as well, there is a TSB out for that problem.
Old Feb 28, 2007 | 08:37 PM
texex's Avatar
texex
Rear is out 5/8"
Old Feb 28, 2007 | 09:06 PM
bigtorque's Avatar
bigtorque
read this.
https://www.ford-trucks.com/tsb/full...hp?tsb=04-23-6
Old Feb 28, 2007 | 09:56 PM
texex's Avatar
texex
will Ford fix this for me for free?
Old Mar 4, 2007 | 03:28 PM
sbrennan007's Avatar
sbrennan007
If your talking about the front end, all SuperDuty's lean to the drivers side. Every single one I've had has and all the other's I've looked at as well.
Just measure from the ground to the top of the wheel well. It's usually about 3/4" - 1". Switching the springs from one side to the other won't correct this. I think it is an effect of the track bar.
I had thought once of putting a higher capacity spring on the drivers side, lets say if the regular spring rate was 5200#, putting a 5600# or 6000# spring on the drivers side, although I don't know if this would even work like you'd think it should or if it would cause something else to be off.
I know on the '04 Dodge 2500 I had, it had a higher capacity spring on the drivers side than the passengers side.
RKCORPS25
Oct 25, 2011 12:23 AM
Shorty 66
Aug 31, 2011 04:20 AM
FordSVTCobra
May 7, 2008 04:43 AM
davew250
Mar 26, 2008 06:54 AM
53f100ala
Jan 2, 2007 01:03 PM
