1978 - 1996 Big Bronco
5.8L Compression???
Old Sep 13, 2002 | 11:59 PM
HollywoodN2O's Avatar
HollywoodN2O
5.8L Compression???
What compression does a 1989 351w 5.8L motor have?
Also I would appreciate any detailed specs you can offer.
Cam lobe, duration, ect...
Old Sep 14, 2002 | 07:38 AM
DeGideo's Avatar
DeGideo
5.8L Compression???
compression ratio:8.8:1
horsepower(net):210@3,800rpm
torque rating: 315 lb.-ft.@2,800rpm
camshaft lobe lift:.278(intake),.283(exhaust)
cylinder head combustion camber volume:63.6cc
engine boreXstroke:4.00"x3.50"
firing order:1-3-7-2-6-5-4-8
oil pressure hot@2,000rpm:40-65PSI
rocker arm lift ratio:1.61
This information was found in Ford's 1989 Specifications Book(book #2) Light Duty Trucks(Econoline,Club Wagon,Bronco,F-150-F-350,F-Super Duty).Hope this helps.
Old Sep 14, 2002 | 12:24 PM
sandslinger's Avatar
sandslinger
5.8L Compression???
Iron Port
13
Jun 25, 2017 10:53 PM
GoinBoarding
Jul 16, 2016 08:55 PM
77150KIDD
Jan 31, 2010 11:44 PM
mauicruza
Mar 14, 2005 01:11 AM
b737
May 16, 2002 11:49 AM
